| Aussie Amplifiers High quality, high performance amplifier modules and accessories |
#11 |
Thanks Anthony!
Regards, Kenneth Lau |
#12 | |
the MG 3.7 sounds absolute awesome !!! Completely different to my Avantgarde Acoustic DUO Omega horns. The problem is, i like the Maggie sound more than the acutal with my horns... ![]() ATM i am selling my horns over an professional brocker on Audiogon. When they are sold, i will order the MG 3.7 directly and must change the amps from my 300B Ceasar II mono's to.... a new amp project! @ Kenneth Great work Could you tell me witch PSU pcb you are using in your amp? BTW, is the case from Modushop / Italy ?
Reference TDA1541A DAC project PCBīs / Tube-I-zator V2.0 PCB / SSHV-Shunt PCB /
Pedja Rogicīs Discrete Diamond Non-Feedback I/V Stage - Stock status in my Blog |
#13 |
Hi, Oliver,
My power pcb is decided by my friend in Hong Kong, also the softstart module. The chassis is made in China, but I may change to another bigger chassis later, thanks! Your work is very very good! Regards, Kenneth |
#14 | |
could you perhaps share the source from the chassis and the PSU pcb? Best regards, Oliver
| Magnepan MG-12 Crossover upgrade | waynebosz | Planars & Exotics | 34 | 22nd June 2011 03:04 AM |
| Magnepan MG-2's | glorocks | Swap Meet | 2 | 16th July 2007 11:25 PM |
| Magnepan MG 10/QR | crossroads | Swap Meet | 0 | 2nd February 2007 05:10 AM |
| Zen 4 uses with Magnepan MG 12s | Zapped | Pass Labs | 0 | 24th March 2003 10:56 PM |
| Page generated in 0.07775 seconds (76.66% PHP - 23.34% MySQL) with 10 queries |
