| Aussie Amplifiers High quality, high performance amplifier modules and accessories |
#2 |
neat awsome work , congrats !
#3 |
#4 |
Clean and cool looking indeed. How does it play?
#5 |
Hi zman01
Thanks for your kind comments. It plays very well, very quiet, clean and powerful. Cheers Anthony Aussie Amplifiers Last edited by The Saint; 1st September 2011 at 10:00 PM. |
#6 |
have you consider doing that amp with a tube preamp stage ?
#7 |
I had done a design with a tube front end some years back now, back at this stage it has not got to a PCB.
With the 6 channel amplifier the tube stage was not considered. The main goal was to have a compact low profile powerful six channel design which did not weigh ton and could be carried under your arm with easy if needed. The remaining goal was it had to sound very good, which it does very much so. Cheers Anthony Aussie Amplifiers |
#8 |
Hi
Could you tell us who is the supplier of the SMPS and also whether it can be used with one or two of your larger modules? Thanks |
#9 | |
and I am using the supply set to +-45 volts. This supply could be used with two nxV300 amp modules or one nxV500 module If you are using 4 ohm loads. With 8 ohm loads 2 x nxV500s could be used on one power supply. Note also with the nxV500 the HV version of the SPS80 would need to be used to achieve full power. For lower powers the standard version would be fine. I hope this helps. Cheers Anthony Aussie Amplifiers |
#10 |
Are these the same nxV203 as on your website?
| Looking for some low profile conical feet? | audi0 | Construction Tips | 0 | 3rd December 2010 05:04 AM |
| Looking for low-profile, but effective TO-220 heatink | luvdunhill | Parts | 1 | 27th February 2008 08:20 PM |
| Low Profile Power Transformer Help | dsavitsk | Tubes / Valves | 5 | 10th March 2007 11:35 AM |
| What woofer for low profile HT sub? | xcortes | Subwoofers | 10 | 29th October 2005 03:54 PM |
| Need new low profile caps for moth amp | August | Solid State | 4 | 9th February 2004 05:45 PM |
| Page generated in 0.10204 seconds (79.05% PHP - 20.95% MySQL) with 10 queries |
