| Aussie Amplifiers High quality, high performance amplifier modules and accessories |
#11 | |
Just so you see the need for high voltage caps. the nxV1200 has a nominal supply rail of 110 volts for the output stage and +-110 volts for the input and driver stage. 125 volt caps would be more than good enough if you could get them in any reasonable supply, so the next level up is the 160 volt capacitors. Theo you might want to try this US company, they might just be able to help. Capacitor Supply, Inc. BTW $38.00 each for those 160v caps is not a bad price... ![]() Cheers Anthony |
#12 |
Figured the supply would be around 100V.
Hmm..... For that kind of thing check out ebay store jea capacitors. Don't buy 1 or 2, those are very expensive and you lose a ton of money. buy in quantites over 10 and you get a very very very good deal. Here is an example (sell the ones you don't need). Hey you may need a huge case after all! 42 Caps for $158 I noticed in the past that they have illogical pricing. Sometimes a single capacitor costs almost as much as their listings with 10 or more. You have to monitor the stuff they have and strike at a good set of caps. Check the date codes too. I'd still post a thread in 'parts' and see what others here think.
My DIY audio projects- PartTimeProjects.com. Last edited by lgreen; 16th June 2010 at 12:25 AM. |
#13 | |
Those caps would be Ideal for the job... connect a bunch of those in parallel would work just fine and very cost effective. I would use at least 5 of those in parallel per channel for the output stage. Cheers Anthony |
#14 |
or you could use jensen capacitors
Not much comes close to DIY audio gear. |
#15 |
Thanks for the suggestions guys.
lgreen I have taken your suggestion and ordered 2 x Pesante Dissipante 4U cases with 10mm milled aluminum fronts and handles from HiFi 2000 in Italy. They look to be very nice cases indeed. A little on the pricey side at about $325 per case with shipping but certainly a good value judging from the quality. As for the caps I've decided to stick with the 3900 uF 160v caps which I originally ordered. I found some better ones for order on mouser but got a lead time quote of 37 weeks to wait for them...not worth it. Anyway once Anthony ships the amps and I complete the build...likely sometime in August I'm hoping to have some beautiful amp porn to post up and make my fellow forum members Jealous. Anthony ... any news on the availablity of your Rev 2 DAC yet? -Theo |
#16 |
Good luck, I'm jealous already!
My DIY audio projects- PartTimeProjects.com. |
#17 |
Well,
At long last I've finished my first NXV-1200 amp build. I've got one more to go. So far my impression of the amp has been that it is very good indeed...lots of power and dead quite. Grabs ahold of my 18" sub and produces tight extended bass. I have not had the chance to really put the amp through its paces but when I do I will certainly post my observations. -TJ |
| Un-assembled PCB kit for the HPA-LSP400se amplifier now available. | The Saint | Aussie Amplifiers | 3 | 22nd April 2011 02:26 AM |
| HPA-nxV300 & HPA-nxV300se what's the difference? | pcsl999 | Aussie Amplifiers | 12 | 21st February 2010 09:06 AM |
| PC Case for amplifier | salesmonster | Solid State | 9 | 29th September 2009 12:23 AM |
| Amplifier Special HPA-nxV200 | The Saint | Aussie Amplifiers | 0 | 7th August 2009 05:50 AM |
| Finest case for amplifier | Eccu | Solid State | 25 | 4th December 2008 03:59 AM |
| Page generated in 0.08842 seconds (86.80% PHP - 13.20% MySQL) with 11 queries |
