| Aussie Amplifiers High quality, high performance amplifier modules and accessories |
#11 |
Banned
Its class A/B or class B?
#12 |
#13 |
Banned
Thanks Boss.
#14 |
In bridge mode, what is the output power for 4ohm load?
#15 |
Hi Nacder
The maximum power that the nxV202ps module in bridge mode driving a 4 ohm load would be around 350 watts RMS. But this would be at a reduced supply voltage level from the normal +-50 volt rails. if the normal voltage rail is used then 4 ohm loads in bridge mode would not be recommended long term as this would exceed the SOAR rating of the output stage. Cheers Anthony Aussie Amplifiers
#16 |
Thanks Anthony.
So hope to see something like "nxV302ps" that can output higher power without bridging. I wonder if this is in your product plan? |
#17 | |
Currently I have no plans to build a higher powered version of the 202ps or the 203ps modules, but you never know...
| Crown D-60 Dual-channel Power Amplifier User Manual For Sale | mv331 | Swap Meet | 0 | 21st May 2009 06:37 AM |
| DUAL 510 - Only one Channel - Repair Help! | sbolduc | Analogue Source | 0 | 23rd April 2009 09:30 PM |
| dual N Channel Jfet | eapavant | Parts | 2 | 8th February 2008 08:10 AM |
| looking for a single channel class D amp module | Thunau | Class D | 9 | 2nd November 2006 04:51 AM |
| Dual tweeter center channel? | Grahamt | Multi-Way | 2 | 3rd April 2005 07:25 PM |
| Page generated in 0.09209 seconds (73.18% PHP - 26.82% MySQL) with 10 queries |
