| Aussie Amplifiers High quality, high performance amplifier modules and accessories |
Hi, I have been looking at your HPA-nxV203PS amplifier which may be what I am looking for.
Just a couple of questions regarding this. 01- When bridged could the bridged channel drive 4ohms? 02- You mention SMPS power supplys, could you recommend a smps that would run a mono or stereo pair of your HPA-nxV203PS? I have been looking at the Hypex modules. 03- What is the cost to upgrade the capacitors to the higher 15,000uf 63 volt units. 04- How much does the heat sink such as the Conrad MF30-75 mounted add to the price. Thanks in advance Nathan |
#2 | |
The 203ps when bridged is only designed to drive 8 ohm loads as when it is bridged it is effectively driving a 4 ohm load. The Hypex 400 watt SMPS would power the 203ps not problem as their nominal voltage output is just right at +-49 volts. Currently I only stock the 10,000uf 63 volt capacitors for this and other modules like it. The 15,000uf would be about the same cost if I had them. Sorry about that The cost of supplying and installing the 203ps module onto a MF30-75 heat sink is $95.00 extra. I hope this helps Nathan, If I can help you with anything else please let me know. |
| LP & HP filter for HPA-nxV203PS | pcsl999 | Aussie Amplifiers | 2 | 24th February 2010 10:04 PM |
| HPA-nxV300 & HPA-nxV300se what's the difference? | pcsl999 | Aussie Amplifiers | 12 | 21st February 2010 09:06 AM |
| HPA NxV 550 or more | Jman554 | Aussie Amplifiers | 2 | 10th November 2009 10:04 PM |
| HPA-nxV201 Released Soon! | The Saint | Aussie Amplifiers | 5 | 23rd September 2009 06:33 AM |
| Amplifier Special HPA-nxV200 | The Saint | Aussie Amplifiers | 0 | 7th August 2009 05:50 AM |
| Page generated in 0.05854 seconds (80.57% PHP - 19.43% MySQL) with 10 queries |
