| Aussie Amplifiers High quality, high performance amplifier modules and accessories |
We now have made available the popular nxV200se and the nxLSP400se
modules in a short form kit. The LSP400se is available now as a short form kit comprising of the PCB, All of the needed transistors, the protection relay, schematic and bill of materials. The nxV200se is now available in two forms. The first comprises all of the SMD devices pre-installed on the main PCB with no other components supplied. The output stage transistors and supply de-coupling and feedback caps would be supplied by the user. The second option is the same as described above only the remaining components are supplied with the main PCB but not installed. Also the nxV200se has now been optimised to use the IRFP240 and IRFP9240 Hexfet devices.
#2 |
Hi
For the LSP400se all of the needed transistors, the protection relay, schematic and bill of materials. And the SMD devices ? they are not installed !!!!It's not easy to find and to solder the SMD devices Best regards Serge |
#3 | |
The solder paste is available from Farnell or RS components all over the world. And for the placing of the SMDs, for a hobbiest this can be done with a pair of tweezers and a heat gun; it works just great!
#4 |
I have taken the comments on board regarding the SMD components
and I have decided to offer the LSP400se boards with all of the SMD components pre-installed on the main PCB. This leaves the end user to supply the much easier to get thru-hole components. I will also be supplying the output stage N-Channel MOSFETs. The short form kits are available now from the web site online store for $129.00AUD each + Postage and Handling, for one or two kits this costs $20.00 Airmail worldwide.
#5 |
Bump
#6 |
Hi Anthony! Happy New Year!
What about the nxV300, are you planning/willing to do a kit-version of this module too? Or any of your other modules for that matter? I think it would be greatly appreciated by the diy-community, as this would make it a bit more diy, and a bit less plug n play. ![]() Regards - Bjørn |
#7 | |
And a very happy new year to you as well It is a real possiblity that this could happen, as later generation amplifier modules are introduced, I will be making the older modules available as short form kits as I have done with the nxV200se and LSP400se short form kits. Have a great year!
#8 | |
The HPA-nxV300 is now available as a short form kit. The kit designation is HPA-nxV300se and it can be purchsed from the online store under the Special Edition Amplifiers section as of now... Last edited by The Saint; 6th January 2010 at 03:40 AM. |
#9 |
hello
Do All the components are included in the HPA-nxV300se ? Do The power transistors are the same than in the HPA-nxV300 product ? Thanks Serge |
#10 | |
Yes all of the components are supplied with the nxv300se short form kit and the kit can be supplied with the Toshiba or IRF MOSFETs.
| 180 watt Short Form MOSFET Amp Kit | The Saint | Aussie Amplifiers | 5 | 26th October 2011 10:30 AM |
| Need help form Germany | JORGETronic | Tubes / Valves | 6 | 30th June 2006 09:00 PM |
| is 6X5 a 6X4 in an octal form? | jarthel | Tubes / Valves | 68 | 2nd July 2003 02:15 AM |
| cabinets in kit form | km | Swap Meet | 0 | 27th December 2002 04:26 PM |
| Beginner To Form | Steve Fay | Introductions | 0 | 27th April 2002 08:47 PM |
| Page generated in 0.11869 seconds (80.44% PHP - 19.56% MySQL) with 10 queries |
