| Aussie Amplifiers High quality, high performance amplifier modules and accessories |
#21 | |
The SRC4392 in the SmartDAC-One as you have guested operates as a Up Sampler. It takes 44.1khz, 48khz or 96khz signal and upsamples it to 192khz which it then feeds into the DSD1794A DAC. Cheers Anthony
#22 |
Regarding the 12 volt power supply, would you recommend anything?
Would a "highend" power supply improve performance? (something better than a plugpack). |
#23 | |
I use a well regulated linear power supply on my SD, we have had them working on 12 volt switchers as well and the work well as we have quite extensive filtering on the smart DAC main board. For the best performance use a linear 12v power supply ![]() Cheers Anthony Aussie Amplifiers |
#24 | |
Did you try the 1794 dac without the SRC4392 Up Sampler ? If so, what was the differences in sound quality ? Thank Bye Gaetan Last edited by gaetan8888; 22nd October 2010 at 12:56 AM. |
#25 | |
When we first built the SD prototype we used a DIR9001 SPDIF interface chip. It sounded good but it did not have the upsampling capability and by comparison sounded quite flat and un-interesting. Just as a side note we have now released the SD for sale as a short form DIY kit and it is available from my web site online shop. It comes with a pre-programmed IR remote control, you just need to add a 12v DC supply and a case to put it in to get it up and running. You also get lifetime firmware updates which will be distributed via email and it is updated via the USB port from a Windows or Linux OS. The USB port currently acts as a mass storage device on the OSs and updating is a matter of dragging and dropping onto the MSD and the firmware is automatically updated. we will be bringing out more fireware updates soon whereby we will be activating the USB port as a qualified USB Audio device in Windows and Linux, so effectively it will turn the SD into a Windows/Linux Audio streamer. One other feature will will be doing in the near future is to use the onboard Ethernet port in much the same way as Squeezebox users currently use the same device for Server based audio streaming. These and other features will be activated via firmware updates as time goes by. Cheers Anthony ![]() Aussie Amplifiers Last edited by The Saint; 22nd October 2010 at 01:25 AM. |
#26 | |
So you replaced the DIR9001 by another SPDIF receiver chip ? Thank Bye Gaetan Last edited by The Saint; 22nd October 2010 at 01:43 AM. |
#27 | |
So we do not need any other type of receiver chip onboard. Cheers Anthony ![]() Aussie Amplifiers |
#28 |
Anthony,
Thanks for your reply. You may need to think about function for non-upsampling Moddang. |
| Page generated in 0.09919 seconds (82.36% PHP - 17.64% MySQL) with 9 queries |
