Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 1st December 2006, 05:16 PM   #51
CarlosT is offline CarlosT  United States
Terrific work, Peter.
I had an artistic question related to all the GC PCB kits out there. The LM3875/LM3886 chip is set up with offset pins at 90 degrees to the PCB plane. How could one use one of the ready made PCBs like your mono kit and turn the chip another further 90 degrees so that it would be parallel with the plane of the PCB?
The answer could be as simple as bending the whole affair another 90 degrees but that hits me as brutish.
A more complicated answer would some kinda 90 degree PCB solderable connector with the odd 1.7mm/5mm pitch...maybe this doesn't exist.
Any ideas?
Old 1st December 2006, 05:32 PM   #52
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
The most advanced GainClone amp yet Send a message via AIM to Peter Daniel
Just bend the pins, here's one example:
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 1st December 2006, 05:36 PM   #53
Nice...except I need the bend the pins 90 degrees the "other" way
In my design the LM3875 would lay parallel to the PCB hanging out the side...not bent in tucked under the PCB.
So...same approach? Bend-N-Pray?
Old 1st December 2006, 05:42 PM   #54
Peter:
A sorta related question to this thread...
Have you ever considered designing and making an inverted GC kit? Your PCBs super compact and simply stunning elegant.
BTW I keep buying more of your kits because I need the rectifying PCBs...not too cost effective eh?
Old 1st December 2006, 05:49 PM   #55
double post...sorry
Old 1st December 2006, 05:53 PM   #56
It will work the other way as well
www.audiosector.com
Old 1st December 2006, 05:55 PM   #57
And this how the pins need to be formed:
www.audiosector.com
Old 1st December 2006, 05:57 PM   #58
I started with invering Clones but later switched to NI designes as I prefer them.
You should've told me you need just the PS section, I could've arranged for that. The kit shipped yesterday already.
www.audiosector.com
Old 1st December 2006, 06:00 PM   #59
Pretty malleable...this is all silly putty under your trained hands, eh?
Old 1st December 2006, 06:03 PM   #60
...You should've told me you need just the PS section, I could've arranged for that. The kit shipped yesterday already.
That's OK...now I'll have 4 AudioSector LM3875 kits that will need rectifying boards in the future
Thanks again.
The most advanced GainClone amp yetHide this!Advertise here!
