| Audio Sector Kits & PC boards from AudioSector |
#921 |
The tubing needs to be exactly 195 mm long. The edge distance for board mounting holes is 22mm for front (RCA side) and 25mm rear.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#922 |
Is there another brand of resistor than can replace the Riken? I have an AudiSector LM3875 Board and want to use premium parts. I orderred parts at partconnexion, but I forgot to order the Rikens...., And if I want to order them, I don't have the minimum order.
But at the job we frequently order stuff from Digikey. What can I order from there that would be as good or almost? |
#923 |
I'm not aware of any resistor from D-K that is almost as good as Riken. Percy carries Kiwame that are almost as good. You can also get Rikens directly from me.
#924 |
Surplus sales of nebraska has some vishay S102C's and sfernice RNC90Y's. I'm not sure how they compare to rikens, but they sound pretty good.
Their minimum order is $10, they have good prices and reasonable shipping costs |
#925 |
What transformer line from Pilton do you use Peter?
#926 |
Standard Power Toroidal Transformers.
#927 | |
#928 | |
#929 |
Front and back (notice amber LED on front panel right corner)
#930 |
Here how it looks inside. As you can see, there are so many applications for the boards included with the kits
