AudioSector-chip amp kits, dacs, chassis - Page 92 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 7th March 2006, 11:09 PM   #911
karma is offline karma  Canada
karma's Avatar
peter where can i pic up square aluminum tubing in ontario?
Old 7th March 2006, 11:12 PM   #912
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Metal Supermarkets have several outlets across Ontario. Also, Access Metals.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 7th March 2006, 11:18 PM   #913
karma's Avatar
sweet found one in my area.
Jeff Vanderweyst
2100 Oxford Street East
London, ON N5V4A4
Phone: (519)659-1212
Fax: (519)659-1213
london@metalsupermarkets.com
http://data.gointranet.com/cgi-bin/u...u=london&cl=16
thanks
Old 7th March 2006, 11:40 PM   #914
karma's Avatar
what grit do you recommend for sanding fresh cut aluminum. to give it that nice smooth finish?
Old 7th March 2006, 11:55 PM   #915
Studley is online now Studley  United Kingdom
Peter
given the increasing interest in computer audio, have you any plans to add a USB (preferably direct USB-12S) input to your NOS DAC?
Old 8th March 2006, 01:04 AM   #916
I use 100 on a belt sander.
I surely think about it, and eventually it will be implemented.
www.audiosector.com
Old 8th March 2006, 05:22 AM   #917
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Thanks for the info on the DAC Peter.
No sooner I ordered the DAC just over a week ago and it was here....... via Canada Post and 5 working days to Oz.
No longer DIY active
Old 8th March 2006, 10:58 AM   #918
karma's Avatar
Originally posted by i.j.russell
2 x 3 ordered.
Have you got diagrams with sizes for the front and rear panels?
[QUOTE]Originally posted by Peter Daniel
[B]Yeah, I got the drawings and can email them to you.
if you get a chance may i get a copy?
thanks
Old 8th March 2006, 03:18 PM   #919
However, the DAC in a wooden enclosure sounds better, and even better without any enclosure (that's how I'm using mine).
Yes please. My email is i dot j dot russell at tesco dot net.
I am going to build both enclosures and see which I like best. Unfortunately, domestic arrangements require an enclosure.
Old 8th March 2006, 03:35 PM   #920
Here it is. Please note that the RCAs openings are only good for Cardas lower line, with custom made attachment. For dual PCB mount, the hole location and size are different.
www.audiosector.com
Copyright ©1999-2017 diyAudio
