AudioSector-chip amp kits, dacs, chassis - Page 91 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 7th March 2006, 05:38 PM   #901
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
And now, for comparison, how metal DAC chassis is built.
There are large pads on the bottom of the board to attach custom made RCA jacks mounts.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 7th March 2006, 05:40 PM   #902
That assembly slides into 2 x 3" aluminum tubing, the board is attached to the bottom using six 1/4" standoffs. That locks the front plate in position.
www.audiosector.com
Old 7th March 2006, 05:42 PM   #903
The power access module has been modified with addition of threaded inserts.
www.audiosector.com
Old 7th March 2006, 05:43 PM   #904
That allows attachment of rear panel.
www.audiosector.com
Old 7th March 2006, 05:44 PM   #905
And here's the complete chassis.
www.audiosector.com
Old 7th March 2006, 06:06 PM   #906
t. is offline t.  United Kingdom
t.'s Avatar
Very nice cases Pete I'm impressed! they look a bit different to those plastic things you see with those Nos dacs on ebay
Keep up the good work
Old 7th March 2006, 06:50 PM   #907
Hi Peter,
You may have answered this in the original Patek thread, but I can't seem to find it.
Where do you get your perforated metal for the top of your "Patek" line? Metal supermarkets? What is the thickness and hole diameter?
Thanks,
Alex
Old 7th March 2006, 06:55 PM   #908
The holes are 0.1" dia with a pitch of 0.190 and 0.330" (diamond pattern), 0.40 thick.
I got that particular material surplus, but will need to buy more. The Metal Supermarkets can order it for you from that place: http://www.diamondman.com/index.html
www.audiosector.com
Old 7th March 2006, 09:47 PM   #909
2 x 3 ordered.
Have you got diagrams with sizes for the front and rear panels?
Old 7th March 2006, 10:25 PM   #910
Yeah, I got the drawings and can email them to you.
However, the DAC in a wooden enclosure sounds better, and even better without any enclosure (that's how I'm using mine).
www.audiosector.com
Copyright ©1999-2017 diyAudio
