| Audio Sector Kits & PC boards from AudioSector |
#871 |
here ya are peter. i added a little glass to the dac.
its kinda like the decware zbox. but with only one source the dac dac sounds the same just a little more base. and it runs on a batterys so there no humm. its funny all the resisters i used on it are leftovers from my lm4780 kit i need to add a ac plug and a relay for charging the battery and its finished cheers. |
#872 |
hmm inards
#873 |
warm glow
and its allso single ended later |
#874 |
to everyone:
i build an integrated amp, based on Peter's SE kit. Have two 1500mF on rectifier board and two 100mF MKPs per each amp channel. I experience quite anoying amount of RF noise comming to the speakers. The power grounds should be OK (ground star with 10ohm rezistor) ....maybe the wires from big caps? also, it seems to be influenced by the level of attenuation... have anyone some idea, how solve the problem?
hayena |
#875 |
If it's influenced by the level of attenuation, it may be generated by your source. When you turn the volume down completely, how is it?
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#876 |
forgot the picture
hayena |
#877 |
When the volume is completely down, the RF is most significant. Yestarday, I changed the stepped attenuator for Nobel pot, but nothing changed....
I had idea, that the cap wires might be too long (around 2 inch). Could it act as an antenna? Or is it rather on the signal path side?
hayena |
#878 |
The best way to figure out if it's from the caps would be installing temporarily some electrolytics on amps board, like 1000uF perhaps, and see what happens.
#879 |
Thanks Peter. I'll try it
hayena |
#880 |
wow those are hefty caps
| Page generated in 0.11200 seconds (73.23% PHP - 26.77% MySQL) with 11 queries |
