AudioSector-chip amp kits, dacs, chassis - Page 87 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 25th February 2006, 07:00 PM   #861
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
The value of resistor will depend on the diode and how bright you want it. With miniature Panasonic diodes, I'm using 62K resistors. For other diodes that value may be different.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 27th February 2006, 04:38 PM   #862
Send a message via AIM to safetyman Send a message via MSN to safetyman Send a message via Yahoo to safetyman
Peter, need your help.
I have eventually finished my LM4780 in parallel configuration. When I powered it up and measured DC at the output, I am getting approx negative 150mV on both side. Initially, when I attached a speaker, I found that the right channel was very much softer than the left, and after a few minutes, there was no more sound from the right channel.
What is your diagnosis of these symptoms, and what are things that I should check for?
One other thing is that when I touch the chassis of the amp, there is a slight hum, and when I lift my hand off it, it goes away. I have not used any grounding for the amp. The side panels, front and back are aluminum and the base is wood. Have not made the cover yet.
BTW, my pre has no DC on the output.
Thanks, Peter.
Shehzad
Aleph 3 - Diehard fan
Old 27th February 2006, 07:52 PM   #863
Peter, I just resoldered the outputs both on the board and the binding posts, resoldered the inputs both at the RCA and on the board, resoldered the jumper on the problem board and changed out an isolation pad. All to no avail. Problem persists.
I'll await your guidance.
Shehzad
Old 27th February 2006, 08:28 PM   #864
You may have grounding problem. When I tried to run two LM4780 boards configured in parallel I had substantial hum noise ( that was not happening with LM3875 in a same setup). I got rid of ground problems by simiplifying power ground connections. It was described here: http://www.diyaudio.com/forums/showt...773#post787773
Now, LM4780 especially configured in parallel, has quite substantial DC offset. The readings you are getting are not way off, but rather on a higher side. Last year I was thinking about using the chips in parallel mode so I measured 100 of them for offset (configured in parallel mode). The lowest reading I was getting was about 80-90mV and as high as 170mV. This was with about 15k input impedance (50k pot in parallel with 22k input resistor). Now, if you use the chips in power amp, you will have preamp connected to the amp with usualy low output impedance. In that case that impedance is in parallel with amp's input impedance and lowers the offset substantially (that will not apply though if your preamp is AC coupled, and it seems like yours is).
The solution would be trying different chips, preferably sorted for low offset, or using a capacitor between R3, R5 and ground (22-47u should be fine). You may try to lower value of input shunt resistor (R4) by half.
www.audiosector.com
Old 28th February 2006, 03:46 PM   #865
Peter, thanks for all your help. I think you are right that's it's a bad chip. I am ordering a replacement and try out the suggestions you made on DC offset.
I also have a look at grounding issues too.
Thanks again.
Shehzad
Old 1st March 2006, 02:01 AM   #866
rjkdivin's Avatar
Default DAC
Peter,
I took one of my All-In-Ones to a HeadFi meet in San Jose, and it was very well recieved by those who auditioned it.
We A/B compared it using a Rotel RCC-1055 as the source against its on-board DAC, and using a Millett Hybrid Head Amp and several different headphones. You may pick up a few orders as a result.
I was wondering if you ever considered stacking the TDA1543s as a possible means of reducing conversion errors? Could this work.....and could the board supply enough current for 2 or 3 chips. Would other components require different values to accommodate such an experiment?
Is this a dumb idea?
Robert
Old 1st March 2006, 02:29 AM   #867
If you stack TDA1543 chips, the I/V resistors values will need to be changed. IIRC, the first Kusunoki DAC was using 4 chips in parallel and all 3 resistors were 1k (with 9V supply). I've built that DAC, but preferred a single chip version. Four chips in parallel had more slamm, but were lacking refinement, immediacy and delicacy of the sound, the virtues I value much more.
Occasionally, I compare my modified NOS DAC to my unmodified ML360S DAC, the NOS is always preferred
www.audiosector.com
Old 1st March 2006, 02:39 AM   #868
hayenc is offline hayenc  United States
hayenc's Avatar
Send a message via Yahoo to hayenc
Peter,
I was considering trying this, but hesitated because it also looked like the 8008 regulator would be stressed. Did you change reg chips when you stacked 4?
Craig
Old 1st March 2006, 03:51 AM   #869
At that time I was using a different regulator: http://www.diyaudio.com/forums/showt...988#post166988
AN8008 would not last feeding 4 chips in parallel.
www.audiosector.com
Old 1st March 2006, 03:59 AM   #870
hayenc's Avatar
Thanks for the confirmation on the regulator. For now, to use your words, I will continue to enjoy the
as I could not agree more and have plenty of other projects to keep me busy and broke.
Copyright ©1999-2017 diyAudio
