#71 | |
With regards to snubber, as some of you noticed, I got excited initially as well, as it dfinitely made a difference, and sound was more distinct and grabbing. Yet, my subsequent test show that everyhting was not right with a snubber, and ultimately, snubber is not an actual improvement. As I designed the amp modules for those two way active speakers: http://soundfusion.ca/download/speakers.pdf , it was in my best interest to try improve on the original design and last weekend I took with me all popularly used capacitors as well as some snubbers and tried to prersent the new ideas to the makers of the speakers. The listening room was pretty well tuned and basically devoted to listening sessions only, with round wall behind the speakers and special damping panels all over. The source consisted of modified Shanling. We were listening to various caps configurations and also snubber with big caps (I used very good 4 pole Jensens here). The snubber was rejected immediately. I could also clearly hear its inferiority. The sound was lacking air, top extention, bass became slow, lacking texture and snap. We pretty much liked Panasonics, as they were quite musical and not boring. Interestingly, 1000u BG N were also rejected as sounding too mellow and tubey (those caps were pretty well broken in, as I was using them previously for half a year). Rubycons ZL had nice tight bass, but the tonal balance was shifted up and it didn't sound right.. Nichicons KZ were overall rather neutral, but lacking that special something that makes you want listening to the music. According to the listeners in that session, 1000u BG STD were absolutely best choice: fast, detailed, extended, with proper tonality. To me, on more complicated passages the sound became a bit less organized with traces of harshness could be observed, but this didn't bother the other two guys. We also tried 100u BG N by itself only. They didn't sound as good as in my system (but the speakers here were rather hard to drive, with 4 ohm impedance and 3rd order networks). They were distorting in bass a bit when pushed, and tonality was on a smoother side with sort of tubey character. For some it may be preferred choice but my two friends were into faster sounds and didn't like it that much. However, adding 1000u BG STD at the bridges (with 2' umbilical to the amp) fixed things substanially and it was pretty good combination (although they still claimed 1000u BG STD at the amp was better). It is not better to me, when I listen at home though ( and my speakers are very easy load). So my current conclusion is that if BG STD 1000 seem harsh to you and you need more smoothness, add 100u BG N at the chip and use the other BG at the bridges. If you need extra clarity and harmony with really delicate sound signature, no sign of harshness or brightness, you listen only at moderate levels on efficient and easy to drive speakers, and your material does not consist of Transe and House music (although it's still works for me) you might as well give a try to BG N 100u (only) and see how they perform. You can always add more capacitance later. But the single, overall most universal choice, something I would use commercially, would be still 1000u BG STD (and no other caps).
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#72 |
Banned
#73 |
Thanks for the writeup on caps, Peter!
I also can't wait until your DAC boards are ready.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#74 | |
#75 | |
Im really disapointed to hear this as i had an integrated amp planned around the snubber, and im sure Brian is too with all the time he has invested behind this snubber idea... |
#76 |
Homer
The one thing that I have learnt from GC building is that they really do have to be tuned to the system, and to your own ears. Generalisations just don't work. Just build a few and play, and make your own mind up. I respect both Peter and Carlos a lot, they have both contributed much to the field, but if it came down to a final choice, I would still go back to my inverted OPA549s with ZLs, Wimas, and Dales. This is not that the others don't sound good, they do, in fact the 4780s are excellent, but the OPAs do it for me, in my system, and my enviroment.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#77 |
Homer,
Well, I was almost ready to invest in the snubber myself, and was already considering the purchase of big Nichicons from Percy. I also made comments that this was an improvement. However, in the light of recent experiments, I feel oblidged to report on my findings, as the previous ones might have been misleading. I can suspect that snubber performance might greatly depend on the system, personal preference and listening education. I'm merely reporting the findings of people whose judgement I trust, and whose advice was always helpful in developing of my designs. As usually, everything has to be tried personally, but I was already receiving numerous comments from other people, using premium kits, and they also did not like the snubber. You shouldn't be disappointed with my comments, as I'm merely reporting findings I've heard from others, (as well some of my own). However, I cannot recommend something that I don't like myself, and I feel it's appropriate to let everybody know about it. Yet, on my boards, there is a place for the snubber, so if someone likes it, can also use it. I believe the time I invested in the snubber, isn't any less that what Brian invested. And I actually listened to the snubber before implementing it on my boards.
#78 |
Pinkmouse is right.
You have to judge for yourself and make decision. Even with my listening buddies, we sometimes not agree about certain aspects, as everybody has personal preferences. Sometimes, I may not agree initially, but later it becomes obvious that I was wrong. The main idea is try things and develop your own taste, not blindly follow others. And learn how to listen. When I look back, 3- 4 years ago, my preferences were completely different than what it is now. Not that it will stay the same also, it's a constant journey with no end on horizon. Remember those swithes in older equipment ( called lodness)? The snubber does very similar thing. Did you ever see loudness switch on high end equipment? I still use loudness in my ghetto blaster though
#79 |
Yes your both right Pinkmouse and Peter. I was disapointed only because the snubber seemed like an exciting new sure bet, but like pinkmouse pointed out, there are no sure bets in DIY audio.
So, since this choice comes down to preference and environment, what capacitance setup would you recommend for me (10 000/1000/100), im a bit unsure after reading all yer findings what setup favours what preference. Im using 90db book shelfs at the moment (Athena AS-B1), I listen mostly to alternative rock, heavy rock, progressive metal, house and some trance. I appreciate well defined base with punch and dynamic highs over smooth tubey sound. I like my mids clear with as much detail as possible (i love hearing new things in my recordings). Of course trying myself is the best, but just an idea for now as my budget limits me. Maybe in the future, i will permit myself to experiment more. |
#80 | |
| Thread Tools | Search this Thread |
| Page generated in 0.14488 seconds (79.52% PHP - 20.48% MySQL) with 11 queries |
