| Audio Sector Kits & PC boards from AudioSector |
#661 | |
![]() Please note that none of the current Levinson products is using that buffer. It was only implemented in what is now called, Legacy Products: http://www.marklevinson.com/downloads/index.asp
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#662 | |
I agree.
Baby Danika, Born January 20th 1:54am.. http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect.. |
#663 |
So tonight I soldered one set of boards except for the LM4780 chip because I think my iron is too big, size and wattage(35watts).
What size wattage would be good to buy? Maybe this one is better?30w iron
Yes! Its cold in Cold Lake... |
#664 |
its probably better to get a temperature controlled one such as one of these. that way you can get just the right temperature for fine work and crank it up ig you need to solder something big.
http://www.lashen.com/vendors/Cooper...r_stations.asp thats just a random page i googled, im suggesting you buy from them, in fact ive never been to that site before. the one i have is just a made in china one i got from a local store. but it works very well. |
#665 |
Those EL2020s are quite expensive, but look very good. My regular source has them for 6,40 Euro a piece. That is three times as much as I have to pay for the OPA604.
They must have been holy chips or something - Pedro |
#666 |
I've seen this acronym several times and wonder what it stands for .
Thanks Joe |
#667 |
#668 | |
Substitute? |
#669 | |
diyAudio Moderator Emeritus
Yep..and then there are also AVC's Autoformer Volume Control. |
#670 | ||
DigiKey carries them at $3/pc (min 50pc qty required). What would be still interesting is to get MAT02/MAT03 in place of 2210 and 2220.
| Page generated in 0.13051 seconds (68.38% PHP - 31.62% MySQL) with 11 queries |
