| Audio Sector Kits & PC boards from AudioSector |
#641 |
Hi Joe,
I sent you the e-mail earlier today. To make sure, I just forwarded it again.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#642 |
I priced out the 750va for my three LM4780s. Kinda like 250va for each one. Do you think it will still be too much for all three hooked up to one tranny? Or do you think a 400va would be better for all three hooked up to one tranny?
Yes! Its cold in Cold Lake... |
#643 |
I never connected more than 2 chips to one transformer. There are some tradeoffs and gains when increasing wattage (although I can't really define them clearly as I didn't experiment enough). From what I remember, with smaller transformers you get more speed and immediacy, with bigger, you gain body and deeper bass, although it may seem a bit "heavy" without enough articulation.
However, since you are aiming at 3 LM4780 chips, which are more current hungry, it may work fine for you.
#644 |
Hi folks
I got my premium DAC kit from Peter( who was very prompt in attending to my order, Thanks Peter!) a few days ago and am just starting on it. I had my eye on a DAC for along time, and this looks like the real McCoy My players have an optical output so I am getting a Torx179 receiver to replace the one that Peter sent-I didnt look at the outputs before ordering. I have ordered a 30VA toroidal locally, and am loking at various possible enclosures. Any suggestions welcome. George Bangalore, India |
#645 |
The wooden enclosure would be best regarding sound signature, no shielding is needed anyway. How about cigar box?
#646 |
I'm getting ready with finalizing the buffer stage. The board is ready for testing. Adding the quality attenuator at the input may create quite a good preamp (at least that's what I'm hoping for).
Each board is one channel; complete PS is on board (only transformer needs to be connected). For balance configuration, when two boards are needed per channel, they can be stacked, sharing same supply. I worked on that board design with Veteran, a diy forum member. This is the same person that was behind the Green DAC board design ![]() Schematic attached (please note that regulators need to be swapped, they are marked incorrectly).
#647 |
Here's a more detailed view, not all components are installed yet.
#648 | |
Regards, Wade |
#649 |
The main reason is that I don't know the tubes
#650 | |
For reference, this is possible, at least in my config. It sounds quite different with the phase non inverted, I can't connect my 'phones backwards so this was quite important for me. Approaching 40 hours now and it is really sounding good, happy at last, very happy!
| Page generated in 0.13374 seconds (74.06% PHP - 25.94% MySQL) with 11 queries |
