| Audio Sector Kits & PC boards from AudioSector |
#621 |
check out page 4 of this thread.
I did the same thing Peter demonstrated... works great
#622 |
You can get Cardas dual RCA from Percy. But you can also easily build your own, using single RCAs. Both boards have solder pads at the bottom to accept home made dual RCAs
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#623 | |
I found Cardas hook up wire very nicely priced at http://www.partsconnexion.com . Are there any US places that sell it? According to their website there is no US distributors.... Where did you buy your S&B102 TVC, I assume you are using this transformer in the power supply for your amplifier. I did a search for the Vendors Bazaar but with out a specific page turning up there is a lot of searching to do in this topic. Google pulls up nothing I found useful for S&B102 TVC. Sorry about the lame questions as I would image you prefer technical ones that can improve things or correct them |
#624 |
Percyaudio.com sells Cardas wire as well. That's the Vampire wire I meant.
S&B102 TVC stands for transformer based volume attenuator; since I build them regularly, I have lots of cutoffs I'm using for signal wiring.
#625 |
Wow!.......................Great chassis...........how about the balanced version?
Jam |
#626 |
The balanced (and buffered) version will be available at some future time as well.
I'm also working on an integrated with TVC front and balanced GC ouput.
#627 |
I want! Well maybe some day...
#628 |
I have been looking over Plitron's transformers. Could I get a little help selecting one? I figured on going with a 300-400va for 8 ohm speakers (I really can not see myself ever having 4 ohm speakers). Based on a price of a 300va on Mad About Sound I assume some where under $50 is reasonible?
I have been looking on Plitron's website but I am not sure how decipher all of the specifications. |
#629 | |
a 300va tranny is going to land you at least 140$ cdn.. ill see if i can find the link to the company i bought mine for.. i bought 3 x 300va trannys @ 16-0-16 for 80$ with shipping.
Baby Danika, Born January 20th 1:54am.. http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect.. |
#630 |
http://www.madaboutsound.com/prod_det.asp?product_id=8
$48 US..... I just figured I should buy from some where based in the USA. Oh yeah could I just get a couple optional specifications? Who manufactures good ones? How good does it need to be? I can get a lot of electronic stuff, but most the time it is not audio worthy. I can get 40% off of stuff from Newark and similiar prices off with other major industrial dealers. |
| Page generated in 0.13903 seconds (65.36% PHP - 34.64% MySQL) with 11 queries |
