Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 2nd January 2006, 01:55 AM   #611
rjkdivin's Avatar
Default CS8414
Peter,
Would there be any advantage (or any problems) in substituting the CS8414 96khz receiver for the CS8412 in your DACs?
They appear to be completely pin compatible.
By the way, I have both of my All-In-Ones up and running with no problems at all.....beautiful sound! I'm beginning the Greenboard now.
Robert
Old 2nd January 2006, 02:07 AM   #612
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
It should be compatible. Some say CS8412 is better, but I never really compared both chips.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 2nd January 2006, 05:24 AM   #613
rjkdivin's Avatar
Default Greenboard
Peter,
A couple more questions on the Greenboard DAC:
1. You included 3300uf caps for C1 thru C4 where the schematic indicates 1000uf....just want to make sure this is okay before I solder them in.
2. I assume that R10 thru R15 are optional resistors that could be used in place of the Line Filter Chokes L1 and L2? Or are they something else? Since they are not on the schematic, what would their values be if they were used?
3. Same question for S1 and S2....what would they be if used?
Thanks,
Robert
Old 2nd January 2006, 05:42 AM   #614
While the all-in-one board is designed specifically for AC power, the Greenboard is more suitable for battery use. That's why it can be configured with battery chargers on board. Below is the schematic for such application:
The S1 and S2 are LM317 regulators. The resistors values are as follows:
R10/R13: 0.2R
R11/R14: 240R
R12/R15: 2k4
The circuit is based on National application notes. The chokes are not installed in such case (there are jumpers on each one, marked with dotted line). In place of R1-R4 switches should be installed to connect and disconnect charging circuit from the batteries.
3300uF caps are fine in place of C1-C2.
www.audiosector.com
Old 2nd January 2006, 10:35 AM   #615
Hey Peter I just ordered the Premium kit. I got a question, what type of wire did you use in your making of say Patek? What type of wire did you use between the transformer and the amplifier? I am planning on having a remote power supply as well. I am not sure if what I will use. What ohm ratings are acceptable for this?
Old 2nd January 2006, 01:05 PM   #616
Originally posted by opt-e
Wiring.. how much does the type of wire matter?
Stranded vs solid core? Thin vs thick? Copper vs silver?
Ideally, what kind of wire should I be using for what purpose?
I see most people use heavy guage wire for power supply wiring and output wiring, and thin wire for low voltage signal carrying wires.
You're bound to get different answers depending on who you talk to.
For what it's worth, I prefer the smallest gauge solid core wire that can be used for the particular application. I am using 30 gauge solid core silver wire for the inputs; 22 gauge solid core silver wire for the outputs; 22 gauge solid core copper wire for the power supply.
Wade
Old 2nd January 2006, 03:16 PM   #617
For signal, I'm using solid core silver (looks like 30ga) that came with S&B102 TVC, I'm not sure where it can be bought. I also like Vampire solid core wire (26ga) that Percy sells.
For power and speaker connections I'm using Cardas hookup wire (19.5 ga). Since I'm using it in umbilical cord, solid core wouldn't work. Also, Cardas seems to work better than everything else I tried so far. Solder pot or high power iron is needed for termination (multiple enameled strands).
www.audiosector.com
Old 2nd January 2006, 08:00 PM   #618
Magsy is offline Magsy  United Kingdom
When I put the SN75179 back in I discovered that a tiny bit of distortion still persists on some tracks during quiet parts in the high frequencies.
Only happens via Coax from my soundcards, all other sources are fine including direct spdif from the back of two different cdroms.
Optical output from the cards converted to coax works fine too.
Bypassing the input driver fixes the issue. I will be trying another SN75179 when I get hold of one
Is the DAC output inverted when input driver is not present?
Old 2nd January 2006, 09:12 PM   #619
The DAC wasn't really designed to work with computer soundcards, although some people use it like that.
Without input driver present and correct connection to CS8412 the output is inverted. I'm not sure if you can correct it by swapping connection to the receiver, but you may try (it will probably depend on source output)
www.audiosector.com
Old 2nd January 2006, 10:07 PM   #620
rjkdivin's Avatar
Default Stacked RCA Outputs
Peter,
Can you suggest a source for the stereo pair stacked RCA pcb mount output jacks that you you supply?
Robert
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
