| Audio Sector Kits & PC boards from AudioSector |
#601 |
At least 200 sets of that DAC has been sold already, and I'm not aware of anybody having a similar problem. It's either player, or a bad chip. I tried variety of transports and there was always compatibility.
Try to increase the value of R6 to let's say 400R and see if this changes anything, although I don't think it would matter. What are you using for a preamp?
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#602 |
Thanks for those pictures, mine looks just the same
![]() I tried 500ohms (the closest I have) there and it made no difference :{ I am using it plugged into a set of JBL active computer speakers at the moment but I also tried it with my headphone amplifier ( http://www.amb.org/audio/mmm/ ) |
#603 |
I have to humbly apologise and hang my head in shame....it works and I have been an idiot.
I wondered when building what the ---J--- marking meant on the topside of the CS8412. Rather than figure it out I thought I'd come back to it. Suffice to say now I realise it means jumper and have inserted the wire, the dac works fine I was studying the pictures joint for joint for about the 50th time when I realised yours has a jumper in there. I now have to put the line driver back in and tidy up the mess I have made At least you know what to tell the next dummie who complains of the same thing Happy new year! |
#604 |
Peter,
Where can I find info about the DAC kit? I didn't find anything in www.audiosector.com Thanks Asen |
#605 |
Magsy does it now work with coax out?
maybe i made a mistake with mine hmm does anyone have problems with coax out? peter should it work with coax out? whats the Difference between the two? coax out digital out cheers
http://www.karmaelectronics.info |
#606 |
Karma,
Coax and digital are the same thing. Coaxial = a cabled connection (not an optical one) Probably your players have it labeled differently, some of my stuff says coax, some digital and some spdif. Now I have added the jumper everything works, my soundcards and the cheap dvd player. Did you place this jumper? |
#607 |
no my pcbs different.digital coax are the same hmm i guese ill need to take another look at mine
thanks.
#608 |
Peter, does this green dac invert phase like the gold?
If so I just swap rxp for rxn and vice versa correct? Thanks
#609 |
Yes, it is invertinging. Swapping those will adjust for correct phase (I do it between input driver and receiver).
#610 | |
