#41 |
The position of the big caps allows to mount this board horizontally as well, if space is concern. In order to accomodate those extra snubber components, I simply moved diodes closer together (comparing to previous versions). I also reduced the hole sizes (for the diodes) so it will be easier to mount them this time.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#42 |
Now the best part. As I mentioned already somwhere else, I'm not that crazy about snubber anymore, and prefer not to use it. I'm getting very good results with AC power and single 100u BG N caps, but with some efficient speakers it may create slight hum of the drivers, or some might prefer more substantial bass signature. So I made extra holes for 1500u Panasonics which can be used together with those 100u caps (preferably BG N) on amp's board. Also, when snubber isn't used, variety of bypass caps are possible to mount in that place, with spacing ranging from 200-400mil.
#43 |
Looks good peter are you going to listen to them tonight ?
Baby Danika, Born January 20th 1:54am.. http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect.. |
#44 |
Very nice Peter. I'm probably going to have to order one before you sell out of them
But really, the boards do look stunning. You're right, they're a nice change from all the red/blue/green boards I've been seeing lately. Maybe you should get wild and do your dac board in Purple or Orange Gotta love all the screening colors out now. Those case-modding overclockers are getting it to permeate everywhere now. I dare say the goldplated/clear screening with the black lettering is by far the most stunning boards I've seen to date, though! Something nice and simple, yet very eye-candyish about them. |
#45 |
Peter,
Neat stuff! It's great that we have so many options, now. I'm particularly interested in your DAC offering. Very nice. Maybe this is thre wrong place and time to ask this, but have you compared your DAC to the other popular kit, the Scott Nixon DacKit or TubeDac+ (TubeKit, in kit form)? Just curious if you have any observations, since some of us have built or are using them. Also, that Ack Dac seems to be highly regarded. Finally, can you tell us what we must be careful of if we omit the series resistor? Thanks, KT |
#46 | |
I was comparing my early prototype to Ackdack, and AckDack wasn't better. This was probably last June, and since then I improved my DAC a lot. When omiting input resistor, check the offset at max volume setting (when using pot at amps input). If no other noises occur, you should be fine.
#47 |
Finally!!! The DAC
![]() Thanks for all the hard work Peter, can't wait to hear it in my system. |
#48 | |
What? Where? I don't see no DAC here? Where can I order? didn't see it on audioselector |
#49 |
I think Peter said he just ordered the boards... so coming soon
![]() i've been asking him about a DAC for quite a while now
#50 |
I ordered the boards this week, they should be ready the next. Before taking orders I want to show the actual boards. Here's the current layout:
| Thread Tools | Search this Thread |
| Page generated in 0.11364 seconds (69.01% PHP - 30.99% MySQL) with 11 queries |
