#481 |
Peter,
Boo!! You're not making your own speaker cables/interconnects?! just kidding.. But considering all the other stuff you've DIY'd, I'm a little disappointed to see manufactured gear in your setup
#482 |
What other gear?
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#483 |
Peter,
Have you ever considered doing a tube DAC? |
#484 |
My DAC has passive output stage and it works fine without tubes. If anything, I'd rather build tube preamp, especially if it seems to work well with chip amps.
#485 |
How's that USB DAC coming along?
#486 |
I got sidetracked a bit experimenting recently with those drivers: Anybody tried FAL drivers?
but I will look into USB DAC soon.
#487 |
peter when i order that kit next week can i get a LM4780 ic off of you? i think i have been a victim of static damage. i was moving the amplifier to another room and i have electric heat so its very dry here. and there was a spark from my finger to the left rca when i was pluging in the source. i powered it up that channel is dead everying tests good just no input weird. this is a first for me
working with chipamps .extra few bucks? thanks
http://www.karmaelectronics.info |
#488 |
No problem. So far it never happened to me yet.
#489 | |
In your picture on post 474, aren't those cardas cables?! Sorry Peter, just giving you a hard time. I better not push you too hard, because next thing you'll be making a die and drawing your own wire just to shut me up
#490 | |
How do you do that Peter? And what is the risk of doing it? Even if I am very satisfied with your kits, I still want to have more (music) out of the amp ;-) best wishes jan ove |
| Thread Tools | Search this Thread |
