Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 5th November 2005, 09:52 PM   #381
tangen is offline tangen  Norway
Default Parallelling LM3875
I'm enjoying my LM3875 kit I ordered from Peter Daniel (very nice guy to do business with). The resulting amplifier was really astonishing. But, it would have been nice with some more power. Have anyone tried to parallell LM3875? What kind of resistors were used? And how did it sound?
Best regards
Jan Ove Tangen
Norway
Old 6th November 2005, 05:38 AM   #382
rdf is offline rdf  Canada
rdf's Avatar
Thank again! Actually, your description suits my needs very well. For me the hardest part of tuning a SET is cleaning up the top end. One of the LM3875 kits sounds like just the ticket for an alternate reference, to go with the other two tube amps and five pairs of speakers cluttering the place that is.
Old 6th November 2005, 09:19 PM   #383
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
AudioSector-chip amp kits, dacs, chassis Send a message via AIM to Peter Daniel
Thanks to the courtesy of a forum member, here's the detailed schematic of LM4780 rectifier's board.
C1/C2 as supplied are 10uF Panasonics FC, but you can experiment with different values as well. Recently some people tried 100/50 BG N caps here (with Panasoncs 1500/50 FC on the amps board) and the results were very good. You might also choose to not install those caps at all.
R1/R2 and C3/C4 are snubber components as suggested by Carlosfm. I'm not a fan of snubbers and I'm not using them. The current values can be found here: http://www.diyaudio.com/forums/showt...529#post748529 There are additional holes on the board, where a cap up to 10,000uF can be installed when snubber is used (that cap would be on schematic in place of C1/C2 and the small 10u caps are not being installed then.
R3 is used to limit the current through the LED and for a small Panasonic red LED, I'm using 68K resistor.
I will be soon posting similar schematic showing the amp board.
Thanks Todd
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 7th November 2005, 01:43 PM   #384
OK, here it is, a proper schematic for LM4780 amp board: two options available, bridged configuration is the same as stereo (a balanced signal needs to be supplied to the amps input). The connections diagram also matches the board's layout (nice touch, Todd)
Resistors values are as follows:
R1/R2 = 22K
R3/R5 = 680R
R0/R4 = 22K
R6/R7 = 270R
R8/R9 = .1R
Rm = 10K
Rz = 2.7R
Cz = .1 uF
The (red) jumper for parallel config mounts like that: http://www.diyaudio.com/forums/attac...amp=1115409304
CHG can be used for connecting circuit ground to the chassis. I'm using 10R resistor when doing that. Please also note that currently 270R series resistors are being used (instead of 1K).
www.audiosector.com
Old 7th November 2005, 04:04 PM   #385
adolphe is offline adolphe  Canada
Very nice. I just finished soldering in the jumpers for my bridged boards yesterday. I'm waiting on my transformers before wiring up the inputs and outputs. These schematics will make things a lot easier.
Thanks!
Old 11th November 2005, 12:09 AM   #386
Anthony Dockril is offline Anthony Dockril
Default Phone Stage
Hi Peter,
How is the phone stage coming along? And hey will it invert phase? As this would mate well with your DAC.
Anthony
Old 11th November 2005, 12:43 AM   #387
It's not gonna happen before NewYear. I'm presently extremally busy with amps building.
The DAC phase can be corrected (to non reversing). You simply need to reverse the connection of two traces from input buffer chip to the receiver. The next board version will have it corrected, I'm also working on optional USB interface.
www.audiosector.com
Old 11th November 2005, 02:44 AM   #388
Default Phone and Dac
Hi Peter,
OK about the Phone stage - keep us posted.
RE: A couple questions about the DAC kit.
With the Dac when will the new boards be ready and how much for the Premium?
Anthony
Old 11th November 2005, 11:06 AM   #389
lohk is offline lohk  Europe
lohk's Avatar
Thanks for the phase reversal correction hint - it is just that simple, very good!
Will you use the PCM2704 for the forthcoming USB DAC input?
I listen to the DAC everyday with pleasure, and already - as it seems to be always - there are friends lining up for one to be made for them...
all the best
Klaus
/lohk/
Old 11th November 2005, 03:24 PM   #390
I'm still not into using computer as a music source ( I have 3 decent transports: ML31.5, ML37 and Technics ZL-1000, all of them modified), but on suggestion from a forum member, I decided to give it a shot. USB interface will be based on PCM2707, but I'm still not into details here yet.
I have left ony 3 of the gold plated all-in-one boards, so I will be ordering new batch pretty soon. There won't be much difference, mostly fine tuning of some traces.
www.audiosector.com
AudioSector-chip amp kits, dacs, chassisHide this!Advertise here!
