Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 22nd September 2012, 05:28 PM   #2901
at last.
14.6Vdc when unloaded.
Now you know how much voltage the R of the CRC must drop to arrive at your desired final supply voltage.
If the R is chosen a little (or even a lot) too big, you can add a second or a third parallel resistor to lower the Vdrop.
Old 22nd September 2012, 06:20 PM   #2902
Send a message via Yahoo to mikelm
I think the supply is finished already no need for further changes
Old 23rd September 2012, 11:59 AM   #2903
endia is offline endia  Turkey
well, i connected transformer to the circuit and measured the voltage after 20R resistors, 11.6 and 11.8Vdc under load..
finally it's ready to working.. thank you very much for your helps and patience
naim
Old 23rd September 2012, 01:01 PM   #2904
Excellent !
Old 22nd November 2012, 06:01 PM   #2905
Stixx is offline Stixx  Germany
Stixx's Avatar
A few pictures of my cased up Audiosector DAC... works like a charm and sounds very natural. My best DAc so far
Old 22nd November 2012, 08:25 PM   #2906
lohk is offline lohk  Europe
lohk's Avatar
More Bentley than Patek - very sophisticated indeed!
(Veneer or full block?)
/lohk/
Old 23rd November 2012, 12:13 AM   #2907
Very beautiful! Great work!
Old 23rd November 2012, 01:11 AM   #2908
ashok's Avatar
Looks great ! Is that vinyl over acrylic sheet ? Looking at the acrylic strip in the middle it doesn't look like wood on either side !
VERY nicely done !
AM
Old 23rd November 2012, 11:57 AM   #2909
Stixx's Avatar
Thank you everybody!
Actually this is Amboina veneer on two blocks of Ureol (high density foam... like hardwood) and a strip of plexi in the middle that I tinted with this car stuff tinting foil. I also included a very dim LED on the board that just makes it through the tinted plexi
Old 2nd January 2013, 10:48 AM   #2910
sangram is offline sangram  India
@Peter, any possibility of you thinking about F5 Turbo boards - based on your current F5 offerings?
Copyright ©1999-2013 diyAudio
