Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 31st August 2012, 09:10 AM   #2881
tom6 is offline tom6  Australia
Default NOS DAC accepts I2S input?
Hi Peter
I've been reading about Ian's I2SFIFO re-clocker project:
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
- I know your DAC accepts spdif or usb inputs but with modifications, could it also work with an I2S input from the above re-clocker (I guess directly into the 1543 DAC chip), or is this not possible?
Old 1st September 2012, 05:07 PM   #2882
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
AudioSector-chip amp kits, dacs, chassis Send a message via AIM to Peter Daniel
The DAC will accept I2S signal directly, I'm not sure about re-clocker format, but chances are it should work fine.
To order kits contact me through forum mail.
Old 3rd September 2012, 07:11 PM   #2883
endia is offline endia  Turkey
Originally Posted by Peter Daniel View Post
Yes, that would be correct connection.
thank you, Peter.
Old 13th September 2012, 05:30 PM   #2884
flotschi is offline flotschi  Austria
Would i be a bad idea to replace the hard to get and expensive caddock resister with some Welwyn MFR3 resistors?
thanks for your answer...
Old 20th September 2012, 03:04 PM   #2885
No problem at all.
Old 20th September 2012, 08:20 PM   #2886
Hi Peter,
i'm reading 11.8V AC from this transformer's outputs. after rectification it should be around 17V DC. is it high or safe? AN800X datasheet says that max input voltage is 20V but there are 16V small BG electrolytics are on the board. what should i do?
thanks in advance..
Old 20th September 2012, 09:26 PM   #2887
Transformer is rated at 9V, so 11.8 readout seems a bit high. Use series resistor after rectification (about 20R in CRC configuration) and this will get you another 1.2 V drop.
I'm using 8V transformers and after filtering the voltage is less than 12V
Old 20th September 2012, 09:57 PM   #2888
there are already four 20R resistors (R1 through R4) after panasonic line filters under the board (bridging to the dac board).. are they sufficient or should i solder some resistors? how can i do that on the green board? thanks.
Old 21st September 2012, 06:32 AM   #2889
R.I.P.
Add a small bridge rectifier and small smoothing capacitor to your transformer secondary.
Measure the "no load" output voltage of the PSU.
It will be a lot less than 17Vdc.
regards Andrew T.
Old 21st September 2012, 08:43 AM   #2890
AndrewT, thanks a lot, will do in the evening..
Peter, what is the max input voltage after rectification?
AudioSector-chip amp kits, dacs, chassisHide this!Advertise here!
