#2851 |
It was here: Commercial Gainclone kit- building instructions
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#2852 |
Thank you Peter. Very helpful as usual!
Jan Ove |
#2853 |
Hi Peter,
do you have a complete Kit from your Phonoclone? I need a 230V Version for Germany. best regards Josef |
#2854 |
Yes, it's available. Send me an email for price list.
#2855 |
hey peter,
im looking to build a 2 channel setup, but wondering if you know of anyone who has done it with a headphone amp built in also. Possibly using a DAC and building that into the set as well. I was thinking a powersupply in a seperate box with 2 transformers (1 per channel). Then both amp channels and a headphone amp in the other box with a switch which will switch both the input signal and power to the headphone amp. input signal given by the DAC. Maybe im getting a head of myself here lol. seperating it all may be better. |
#2856 |
You will find more info here:
LM3875 as a headphone amp (another try) AudioSector-chip amp kits, dacs, chassis Commercial Gainclone kit- building instructions
#2857 |
Hi all,
I am searching for the right part, for input coupling cap. I have found what was a favorite of Peters at one time: "and my two favourites for coupling are 4.7u BG N or 100/25 Rubycon ZL" on an old thread in here. Far as I can tell, we can't get the Black Gate anymore. A few have some left over, but I can't find that 4.7uF value cap. In looking for an altranate, what voltage should be used? I found an Elna 4.7uF 50V, ROA Series. Also a Rubycon ZA 4.7uf 35volts. Would either of those work? Thanks, AlexQS |
#2858 | |
Peter in past suggested me to use Rubycon ZA 4.7microF and I bought them online at referenceaudiomods Renato |
#2859 | |
This is the best kind of help for me, when you list a vendor name as you have. Seems like half my problem is not knowing where to shop, but I'm learning. Sincerely, AlexQS |
#2860 | |
| Thread Tools | Search this Thread |
| Page generated in 0.12313 seconds (77.29% PHP - 22.71% MySQL) with 11 queries |
