Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 4th January 2011, 07:59 PM   #2751
Holty is offline Holty  United Kingdom
Thanks Peter for reply.
Old 5th January 2011, 08:25 AM   #2752
Hi Peter
I received the DAC yesterday and have soldered the jumper (for 230 volt setting) as below. Can you check that all looks in order please? I am getting no sound from the DAC.
Old 5th January 2011, 02:05 PM   #2753
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Hi, Sorry to hear that.
However, you are using previous generation board, with different traces layout and no jumpers marked in a bottom layer (you can see them in top layer though). So you should have consulted me before making any connections, as obviously that board is DIFFERENT than the one from my previous picture.
What you did was connecting live and neutral together and blowing the fuse, that's why no sound from a DAC.
With that board version, you need to jumper the OTHER two pads. If sourcing pcb mount fuse is problematic, use a regular fuse.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 5th January 2011, 02:36 PM   #2754
Thanks Pete. I feel a total spaz.
Will sort it now. A PCB mount fuse should be easily obtainable.
Much appreciated.
Old 5th January 2011, 03:28 PM   #2755
or use a bulb tester every time you modify a mains powered project.
regards Andrew T.
Old 21st January 2011, 10:23 AM   #2756
Okey, so I recieved my LM4780 dual mono premium kit, now everything is soldered together.
However when its hooked up to my preamp/dac its producing around 1.1VDC at the output, on both channels.
Without hooking it up and with inputs shorted I get 6.2mVDC on one ship and 4.7mVDC on the other. When measuring DC offset on the pre I get 2.3mVDC/3.3mVDC.
I hooked it up to a pair of shitty speakers, sounds good but it seems to be some HF noise present.
When I hook it up to my iPhone, bypassing the pre its totally noise free and the DC generated at the output is 11mVDC/0,1-0,8mVDC (to low to be measurable with my multimeter)
Lifting the earth solves nothing and gives no noticable change.
Would an AC coupling cap in series with input solve my problems when using it with my preamp?
Old 21st January 2011, 11:16 AM   #2757
the Audiosector amp is DC coupled.
regards Andrew T.
Old 21st January 2011, 12:14 PM   #2758
So adding a DC blocking cap at the input wont do any good then?
Then how should I solve this issue!
Old 21st January 2011, 02:28 PM   #2759
It would certainly reduce the offset, although most likely not to lowest value possible like you are getting with iPhone.
The amp offset is also dependent on impedance present at amp's input; if the source's output imp is very low, the offset is minimized as well.
As to the HF noise, try to install 300pF cap between pins 15-16 and 21-22 on LM4780, which would be a similar approach to what I recommended for LM3875: Commercial Gainclone kit- building instructions
www.audiosector.com
Old 21st January 2011, 02:54 PM   #2760
The Preamp used is the HLLY DMK-IV
I've not found any information regarding the output impedance of the preamp.
Is the 1VDC offset caused by the offset from the preamp, or is there anything else that's likely to cause this?
Is there more measurements that I can do to narrow down my troubleshooting?
Max
Page generated in 0.13424 seconds (74.90% PHP - 25.10% MySQL) with 11 queries
