| Audio Sector Kits & PC boards from AudioSector |
#2731 |
Peter, when you said "threading the wood", does it mean that you tapped the wood? I am particularly interested in how you fixed the two screws in the image attached here. The two screws in the image are wood screws? Or do you mean that you use wood screws at the side panel to attach the wood (not the ones shown by arrows in the attached pic)? I happen to you the same wood (wenge) for my chassis!
The Great Saiyaman Siapa bertelinga hendaklah ia mendengar... (Mat 13:9) |
#2732 |
Yes, the wood screws are used on side panels (from the inside). The screws in rear panel (as indicated in your pic) are #4-40 machine screws; the wood is tapped after treating the holes with crazy glue to add stiffness to the thread.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#2733 |
There are threaded metal inserts that I find are preferable, as you cannot strip them.
Also, ski shops have the "helicoil" that they use when binding holes in the ski become stripped. Vast holding power. |
#2734 |
Peter have you noticed any affect to changing capacitors mounted on the 3875 chip boards and dampening factor? I am using some fostex based speakers and find the noise slightly overbearing and perhaps a touch on the flat side dynamics wise. I am thinking about seeing what I can do to experiment a little. Also what pins do you put a 330pf capacitor on if you get FM again? I now live next to a different radio station....
#2735 |
The capacitor placement was explained here: Commercial Gainclone kit- building instructions
I didn't do any observations with regards to dampening factor.
#2736 |
Hi Peter
I need to build a 100w p/c amplifier to drive my 8 ohm speakers. I was looking at various options and have come to the conclusion that LM4780 bridging would solve my problem, in the least no of parts. But going through the application notes/overture design guide, i have realised that heat would be one major concern and as i live in India the ambient temp is also not close to 25C throughout the year. so here are my queries 1. How much power for an 8 ohms load, would one of your boards(having one 4780) provide, in mono config? 2 . If i bridge the boards how much power should i expect realistically,for say +-28V PS, keeping in mind the heat issues? 3. Will a BPA design as seen here be possible using your boards. regards anurag |
#2737 |
In bridge mode you can expect approx 120W from a single chip. You need an additional circuit though to convert unbalanced signal into balanced.
He's actually using my boards in a pic here: bpa-200-2.jpg (image) so I guess that design is possible with my boards.
#2738 | |
#2739 |
Peter,
Just a quick note to let you know my LM3875 kit with the Case you offered is still going strong since April of 2004! along with the NOS DAC from April of 2005. They both get every day use in the media room driving my B&W 805's. Excellent sound and very durable! Thanks for all of your excellent work and sharing your expertise with all of us over the years. (now i need to order a USB DAC!) -m. |
#2740 | |
Still.. the Integrated-amp is sounding great and never had a problem! I think I have it since 2007, and only unplugged during some holidays when I am out of the country. Thanks!
They must have been holy chips or something - Pedro |
| Page generated in 0.13540 seconds (70.44% PHP - 29.56% MySQL) with 11 queries |
