Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 12th June 2009, 11:17 AM   #2641
wlowes is offline wlowes  Canada
wlowes's Avatar
Originally posted by cyxg
i also got USBDAC from you. it's very good sound and convenient to play WAV or APE by Foobar2000.
cyxg
Give the DAC a good 100 hours to fully open up. The blackgates continue to get better over 300 hrs. I leave mine on all the time and it is excellent.
Then drop Foobar and pair CPLAY & CMP to this DAC and you will be blown away. Very short USB also good.
http://www.audioasylum.com/forums/pc...s/3/31286.html
walter
Old 12th June 2009, 12:47 PM   #2642
cyxg is offline cyxg  Australia
Originally posted by wlowes
cyxg
walter
thank you walter.
i will try.
Old 22nd June 2009, 12:13 AM   #2643
bluemartini is offline bluemartini  United States
bluemartini's Avatar
Peter, it has been a couple of months and was wondering if you have anything to report on the "more serious project"
'All in all, I'm very content with that unit and I use it in my workshop for music, internet and video. I have another, more serious project coming up soon.'
Old 26th June 2009, 07:52 PM   #2644
samoloko is offline samoloko  Bulgaria
Peter
would you give your recommends for a BG (N and STD) substitutions
are nichicons (too many types) good, rubycons or pana FM/FC
Old 27th June 2009, 06:45 PM   #2645
martinbls is offline martinbls  Germany
Hi Samoloko,
I've never heard of real substitutes for Black Gates when it comes to electrolytic caps in coupling / decoupling applications. Further more, sound of caps really is a matter of personal taste. I would go for some nice film caps, MKP's or KP's.
If size matters, I would recommend to outsource the caps from the pcb completely. Then you have the possibility to try every cap you want.
I did the same in a recent project when I decided to use some russian military pio's, bypassed with a small film cap of same value. Very nice result, and much better than some ordinary electrolytics...
Regards - martin
Old 27th June 2009, 07:11 PM   #2646
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
AudioSector-chip amp kits, dacs, chassis Send a message via AIM to Peter Daniel
Originally posted by samoloko
Peter
If not BGs then Panasonic FC; some people also like BC Components caps, but I never tried them.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 27th June 2009, 07:16 PM   #2647
thx for very kind reply Martin
It has to be a electrolitic cap which has closer to BG N sound
I don't have much practice thats why I ask
Old 28th June 2009, 01:02 PM   #2648
Ok, then perhaps this test might show you some alternatives:
http://www.ecp.cc/cap-notes.html
There is also something said about some Panasonics and Nichicons.
Happy reading ;-)
Regards - martin
Old 29th June 2009, 03:28 PM   #2649
Peter
have you think what you would use for a replacement of BGs
after all they are not In production
why do you like pana FC more than FM
also what you think about nichicon and rubycon for couple / decouple
Old 29th June 2009, 03:39 PM   #2650
I expressed my views on capacitors here: http://www.diyaudio.com/forums/showt...431#post574431
http://www.diyaudio.com/forums/showt...230#post581230
I've been using Panasonic FC for many years and don't plan replacing them with anything else. BGs were fine, but only for limited production of certain amp models. I still keep substantial stock of Black Gates for future needs (to be used in actual products only and not sold for parts).
And why would I like FM if FC work fine for me?
The only other caps I would be interested to try out are already mentioned BC Components (used originally in Gaincard)
www.audiosector.com
AudioSector-chip amp kits, dacs, chassisHide this!Advertise here!
