AudioSector-chip amp kits, dacs, chassis - Page 252 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 17th January 2009, 10:17 PM   #2511
raypalmer's Avatar
I love how elegant your grounding solutions always are. Is the resistor necessary? Or does it just reduce noise.
Wherever you go there you are.
Old 17th January 2009, 10:20 PM   #2512
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
It separates amp ground from chassis ground which is connected directly to Earth ground. It is not neccessary and I had amps without that resistor.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 23rd January 2009, 03:10 AM   #2513
raypalmer's Avatar
Okay my LED isn't lighting up... Everything look okay in there to you guys??
Old 23rd January 2009, 03:33 AM   #2514
What value resistor did you install for R3? The diode is polarized and will light up only with long pin on +
www.audiosector.com
Old 23rd January 2009, 04:15 AM   #2515
raypalmer's Avatar
The Square pad on the pcb is + no?
Also, what's the source voltage? Would it be 24V because I have a 24v sec on the rectifier?
I have an 820ohm resistor on it (it's a yellow LED with a 30mA forward current and 2.1 forward v.
Old 23rd January 2009, 04:26 AM   #2516
Yes, the square is on V+, however, 820R is probably too small. I'm using 22k with Panasonic miniature yellow LED and 62K with the red.
www.audiosector.com
Old 23rd January 2009, 04:30 AM   #2517
raypalmer's Avatar
Okay... I can't find a chart with resistor values that helps me with my LED, any idea what I should be using instead?
Incidentally... I'm only getting .8v AC coming out of my traffo and 1.2ish dc of the bridge. Do I need a load attached or is something terribly the mattter.
Old 23rd January 2009, 04:32 AM   #2518
It looks like the fuse might be gone. I would try 20k first with a LED and then adjust for desired brightness.
www.audiosector.com
Old 23rd January 2009, 05:44 AM   #2519
raypalmer's Avatar
Fuse intact, swapped in a new one jic. I flipped my primaries and the bulb tester lit up so I know I was on the right primaries. I read less than a volt AC at the secondaries and just over after the bridge. Is it possible my traffo has taken a dump in-between now and when I bench tested?
Old 3rd February 2009, 04:31 AM   #2520
RKH is offline RKH  United States
Default Pics of my DAC
Trying to upload a photo of my DAC...let's see. Okay, that worked. I wanted to say thanks to Peter for the fabulous kit. My version here worked first try (Peter soldered the surface mount components). I put the system (described in the next paragraph) together in one go so I don't have proper before-after comparisons. All i can say is that it sounds great.
The DAC is mounted on a solid piece of what started out as 8/4 cherry. My source is iTunes with lossless files feeding the DAC. The DAC supplies Pete Millett's hybrid headphone/pre amp which in turn drives a Decware Zen experimenters Tube Amp (built from kit... I can supply photos of the whole set up if anyone is curious.) Those 1.8 watts drive some vintage Klipsch Heresys.
I'll stop there. As I said, it all sounds fabulous. Life is good.
Ryan
Lighten up while you still can ...
Copyright ©1999-2017 diyAudio
