Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 22nd December 2008, 03:29 AM   #2401
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
AudioSector-chip amp kits, dacs, chassis Send a message via AIM to Peter Daniel
I didn't like them at all: http://www.diyaudio.com/forums/showt...129#post162129
Still have few left, if somebody's looking for sample.
To order kits contact me through forum mail.
Old 22nd December 2008, 03:33 AM   #2402
EUVL is offline EUVL  Europe
Thanks for the info.
Patrick
Old 22nd December 2008, 03:41 AM   #2403
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
So would I connect my binding posts ground to the star power ground, and then from there run some more wires to the OG?
Old 22nd December 2008, 03:47 AM   #2404
Not exactly, those pictures show it best (the black wires are from PG+/- on rectifier board)
Old 22nd December 2008, 03:50 AM   #2405
Peter you need to update your PDF for the 3875 kit. It would be really hard to explain where all the information came from to get my amp where it is now. The process never ends.
You sure I can not just connect it all to the star ground? I am mostly just trying to avoid an assload of work.
It looks like you do not even have PG+ or PG- on the amp board wired to anything, are they just grounded through OG, and the ground from speaker binding post meets up there? Then they go to PG+ and PG- on the rectifier board?
Old 22nd December 2008, 03:54 AM   #2406
That pdf is not mine, I'm just posting it there as it may be useful for general info, the specific info with regards to my kits is here: http://www.diyaudio.com/forums/showt...3&pagenumber=1
You may try to connect it all to star ground, but the method described earlier is probably most elegant.
Old 22nd December 2008, 03:57 AM   #2407
That's the main thing: in some setups multiple wires from rectifiers PG to amp PG were creating noise, that's why I switched to the other method: connecting OG points from both channels; central point on that wire is your power star ground.
Old 22nd December 2008, 03:58 AM   #2408
I will go try it.
Thanks again Peter.
Old 22nd December 2008, 04:42 AM   #2409
Still got noise.
I assume it is the toroidal that is too close. It is an Avel not a Plitron too. I thought Plitrons cost way more, and they use to take like two months or more to get so I got the Avel this time. Although if it is FM well I have no way to tell, it sounds like nothing. Perhaps I should add the cap, will it do anything bad for sound?
It sounds the best it has sounded though.
I took the cover off, removed some extra PG wires I forgot about. Still got sound.
When I turned it on without the case lid on the sounds from the speakers sound like the transformer. When the transformer powers on it is like twice as loud.
Old 22nd December 2008, 04:06 PM   #2410
Maybe you could post some pics of your setup?
AudioSector-chip amp kits, dacs, chassisHide this!Advertise here!
