Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 17th April 2008, 11:07 AM   #2161
audio1st's Avatar
JohnM, here is a better picture of one of Peters amps, it shows the connections more clearly.. All you will have to do is disconnect one PG+ and one PG- and see if the hum goes..
Old 21st April 2008, 09:22 PM   #2162
JC Fardo's Avatar
Hey Peter
NOS DAC singing! A LOT!
Thanks so much for kit and kind support.
Jose
Jose Carlos
Old 23rd April 2008, 04:15 AM   #2163
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I think it was only a matter of time before I started building Integrated amps with a DAC built in. Here's the first one, with USB input:
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 23rd April 2008, 04:19 AM   #2164
I couldn't fit the DAC transformer inside, so additional turns (20 and 27) have been added on Plitron toroid.
www.audiosector.com
Old 23rd April 2008, 04:29 AM   #2165
The DAC board has been separated and main filtering section slightly modified.
www.audiosector.com
Old 23rd April 2008, 04:39 AM   #2166
www.audiosector.com
Old 23rd April 2008, 06:58 PM   #2167
Peter,
What type of wiring are you using for the input/output jacks?
-claiborne
Old 23rd April 2008, 07:09 PM   #2168
I use 26ga gold plated solid core copper for signal wires, Kimber TCSS 19ga for output and Cardas 19ga for power.
www.audiosector.com
Old 23rd April 2008, 07:40 PM   #2169
Peter,
Thanks for the closeup picture and reply. I always enjoy seeing closeup shots of your craftsmanship. Your work is beautiful!
-claiborne
Old 23rd April 2008, 08:05 PM   #2170
karma is offline karma  Canada
karma's Avatar
yes peter nice work as allways
Page generated in 0.11920 seconds (73.54% PHP - 26.46% MySQL) with 11 queries
