Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 11th April 2005, 07:48 PM   #191
homer09 is offline homer09  Canada
homer09's Avatar
Originally posted by Peter Daniel
It's the other way: acrylic has cutouts for aluminum bars. Although not really neccessary, it simplifies assembly as everyhning locks in place, and improves appearance as well.
I really agree, the cutouts are the magic touch on that rack
any reason why top shelve is much thicker than bottom ones?
Most people wouldn't know good music if it came up and bit them in the ***. - Frank Zappa
Old 11th April 2005, 08:39 PM   #192
Stabist is offline Stabist  Slovenia
Stabist's Avatar
Aha - so you made all plexiglass work by your self ...
Is it hard to do those cutouts in plexi??
Interesting - been considering about pretty much similar stand for my "Patek Line" recently - but ofcourse - "student budget version" - so smaller and with thinner (15mm ones) shelfes and only 2 wide Al bars at sides for suport ...
Old 11th April 2005, 08:45 PM   #193
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
It's pretty easy to machine it. The cut outs were done on all 3 panels simultanously, by multiple runs over a router straight bit.
The top panel is thicker, because I had that particular material in stock, and since the top shelf supports a transport, more solid foundation is achieved. All material was bought surplus. The design was dictated by what was available at the moment of coming with the idea
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 11th April 2005, 09:41 PM   #194
Stabist's Avatar
What about drilling and tapping?
I've drilled into plexi some time ago - and until holes were around 3-4mm in diameter - without any problems (at lowest speed possible that my stand alone drill machine provides) - but when trying to make 7-9mm - auch ...
Any tips??
Old 11th April 2005, 10:27 PM   #195
I used 1/4" screws, didn't have any trouble with drilling and tapping. Use some lubricant, it definitely helps, don't let the drill get stuck when it's hot, as it hard to remove it later
For plastiks the drill bit should have sharper angle on the tip.
www.audiosector.com
Old 15th April 2005, 07:10 PM   #196
r8833 is offline r8833  Canada
Smile premium dac kit
just received Peter's premium dac kit..looks awesome and easy to finish... Thanks Peter
Old 16th April 2005, 02:04 AM   #197
I made DAC enclosure prototype today. It's pretty straight forward, and no milling is required. If the tube length is chosen properly, attaching font and rear panels can be done by means of on board connectors: RCAs and power module. Additionally, front panel can be glued permanently, rear one provides access to the inside.
The finish is by brushing (on belt sander) and applying alodine, which gives the stainless steel look to the aluminum.
www.audiosector.com
Old 16th April 2005, 02:12 AM   #198
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Looks nice peter : O )
Old 16th April 2005, 08:37 AM   #199
Peter, you're brutal. You make it look too dang easy.
Old 16th April 2005, 09:11 AM   #200
Hanzwillem's Avatar
I thought you preferred wood for at least the bottom plate
They must have been holy chips or something - Pedro
Page generated in 0.11628 seconds (74.46% PHP - 25.54% MySQL) with 11 queries
