| Audio Sector Kits & PC boards from AudioSector |
#1971 |
hi,
and the flexible leadouts allow rotation of the transformer to orient the hum field for minimum noise.
regards Andrew T. |
#1972 | |
Ah, good point Can you explain it in detail how to achieve the optimum transformer orientation? Is it just simply trying to orient the transformer and listen for the resulted hum? Joshua |
#1973 | |
Banned
Correct, also mounting it above the chassis, ie on a block of wood or rubber helps. |
#1974 |
In regards to rotating transformers, is there are way to be sure to get the orientation right the first time ?
If not, what are the maximum degrees of rotation necessary ? Once these things are wired up, it'll be a major pain of you need to rotate 180 degrees, only to find the wires aren't long enough !!! |
#1975 | |
Banned
Its not a HUGE issue, your best bet is to make sure the wires are short and cleanly soldered to the board, another good thing ( noted above ) isolate it from the chassis. The less hum you can create the beter, gain clones are very prone to hum You can look at it and recieve hum LOL, im sure you'll be fine tho.
#1976 | |
Thanks for the tips! Joshua |
#1977 |
Does anybody have any experience of using magnet wire for interconnection for gainclone amp in particular ...or for any amp in general?
Is it a benefit or vice versa? Let me hear your comment please..... ![]() Thanks in advance! Joshua |
#1978 | |
Banned
#1979 | |
Right, i might give a try but later...:P.. Thanks for the prompt response. Joshua |
#1980 |
Peter,
I notice in your Patek Amp design, you put a chassis connection from the star point ground thru a small value resistor. I believe this is for safety reason in which it gets connected to the earth ground connection at separated power supply module...cmiiw.. That brings me to another different question, does the 0 volt point at secondary side of the transformer has always to be connected to the earth ground? Can we just leave it floating? Thanks, Joshua |
| Page generated in 0.13628 seconds (75.80% PHP - 24.20% MySQL) with 11 queries |
