Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 28th September 2007, 11:31 AM   #1921
reMC is offline reMC  Netherlands
reMC's Avatar
Turns out I don't need a LED because the dac works
The weird thing is that it only started to work after I connected pin 16 to +5V... and I have never seen a scheme before in which this was necessary
Old 1st October 2007, 04:26 PM   #1922
arild is offline arild  Norway
Been listening to your DAC and LM3875 amp for a few days now they both sound great Peter. I would like to be building a balanced version of your DAC next. what kind of sound improvement can i expect with V-caps in the DAC?
Old 1st October 2007, 04:57 PM   #1923
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
AudioSector-chip amp kits, dacs, chassis Send a message via AIM to Peter Daniel
Unless the stage after the DAC has very high input impedance (100k or more) you would need to use large coupling caps. With V-Caps, it will cost you a small fortune ($300 or so).
One solution is to use high impedance buffer and 0.1uF caps. A Borberly simple buffer (5 components or so) would be suggested here as it can be build with high impedance input.
As to V-Caps and the overall improvement, it is rather subtle. The V-Caps don't work well with Rikens, you need to switch to Caddocks TF020 ($6 ea). Even then, the improvement is some 10% or so: sound is a bit more transparent and detailed, but you loose some musicality as well.
To order kits contact me through forum mail.
Old 3rd October 2007, 12:28 PM   #1924
Chunkeymonkey is offline Chunkeymonkey  United Kingdom
I'd like to put together a 3875 kit, but will need to add a pot for volume control. Searching seemed to indicate a 10k lin is a good value.
I can get a basic Vishay for about 5 /$10, an Alps Blue for about 10 / $20, I also read on an old post that you have some Noble pots.
Are these still available, and will it give much improvement over the Alps?
thanks
Mark
Old 3rd October 2007, 12:31 PM   #1925
reMC's Avatar
Does anyone have a explanation for this (I hope it's OK to ask the question in this topic)?
Old 3rd October 2007, 01:49 PM   #1926
Blue Alps supposed to be good, but I never tried them with my amps. I use Nobles, 25K or 50k, depending on availability. Both work fine and I have 50K in stock presently.
Old 3rd October 2007, 10:12 PM   #1927
Thanks for the reply Peter, how much are the 50k's. I don't know if Nobles are still made but I saw one over here for about 40 /$80.
It seems odd to spend as much on the pot as the kit.
Do you have any advice on hook up cable, solid cores seem very poular, even network cables. Is there much that can go wrong sonically with stranded, or is it more a case of finding a flavour you like.
Markus
Old 3rd October 2007, 11:25 PM   #1928
I would say it's more about the flavour. I like solid core 24ga for signal (I use here gold plated copper). As for PS and speaker connection, Cardas and Kimber, 20ga stranded.
The Nobles are $24 (older production, 34 detented steps)
Old 17th October 2007, 09:23 PM   #1929
rickmcinnis is offline rickmcinnis  United States
Default Any thoughts on power cords?
Peter,
What do you use for a power cord on your 3875 amps?
Do you think it matters?
Do you have a favorite recipe for the DIY obsessed?
I am about to try AC power for my sub 500 hz amps and thought I would get your (most valued) opinion.
Thanks,
Rick McInnis
Old 18th October 2007, 11:53 PM   #1930
wlowes is offline wlowes  Canada
wlowes's Avatar
Default Re: Any thoughts on power cords?
[QUOTE]Originally posted by rickmcinnis
[B]Peter,
I could not help commenting... I am happily running one of Peter's 3875 amps. I was always skeptical about power cords making a difference. Wrong! By accident I replaced a heavier guage computer power cable with a light guage, and the sound really degraded on the amp. Now I thought, what if I had a good power cable.
I built a cable based on Chris VanHaus design..
http://www.venhaus1.com/diymains.html
Wham, amazing improvement on an already great amp. Sound stage became pin point precise and 3d. Base much more extended. I am a believer.
AudioSector-chip amp kits, dacs, chassisHide this!Advertise here!
