Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 15th September 2007, 03:33 AM   #1911
d to the g is offline d to the g  United States
d to the g's Avatar
Default Re: my new gc
Originally posted by rnzr
hi,
a little showoff of my new gainclone
both the site and the amp look professional. hope it sounds as good as it looks.
Old 15th September 2007, 09:22 AM   #1912
rnzr is offline rnzr  Estonia
Thanks! Actually yes, it sounds good as it looks
This is not special website, it's just a flash gallery script (imagevuex.com)
Old 26th September 2007, 01:03 PM   #1913
kmj is offline kmj  Sweden
kmj's Avatar
Hello again, I an in the process of putting one of your DACs together and I have a few things I need to get sorted out. I got the bare PCB and no components and it is the L1-L4 thats causing my problems, there aren't any specs listed in the schematic, neither on the partslist.
So, could you tell med the values and tolerances on these four inductors?
And one more thing. C5a and C5b? There are only room for one C5 on the board.
The DAC in question
(I would send Damien a mail but no contactlink is specified, at least not when I checked a few minutes ago)
Kind regards
K.
.....Where the music comes to die.
Old 26th September 2007, 02:29 PM   #1914
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
AudioSector-chip amp kits, dacs, chassis Send a message via AIM to Peter Daniel
Actually, when you check attached schematic, L1-L4 are marked as PLK1077 (Panasonic) and P9818 (Panasonic); those are DigiKey part numbers.
With a Green board you use only C5; C5a and C5b is with respect to all in one board where power traces are longer and two separate caps are being used.
To order kits contact me through forum mail.
Old 26th September 2007, 02:32 PM   #1915
And it looks great indeed, congratulations!
Old 26th September 2007, 03:36 PM   #1916
kmj's Avatar
I'll be...
It seems like the schems on my computer is missing some stuff.
I'll update them. And ofcourse, thanks
Old 27th September 2007, 10:32 AM   #1917
reMC is offline reMC  Netherlands
reMC's Avatar
Hi Peter,
I have a question about the scheme you posted here. Shouldn't pin 13 also be grounded?
Thanks!
Old 27th September 2007, 01:20 PM   #1918
Pin 13 can be grounded or not; in my board it's not.
Somebody asked me about it few years ago and I did some comparisons and IIRC not grounded sounded better.
Old 27th September 2007, 01:27 PM   #1919
reMC's Avatar
Ok, thanks for your reply. Something new to experiment with!
Another question (it's been asked before but I can't find a clear answer): I want to place a led on my board to check if the signal is locked into the receiver. If it's locked, I want the led to go out. Is there a way to do that?
Old 27th September 2007, 02:04 PM   #1920
It surely can be done, maybe using transistor driving a relay?
However, why would you need it a LED; unless something is broken the DAC is always locked
AudioSector-chip amp kits, dacs, chassisHide this!Advertise here!
