AudioSector-chip amp kits, dacs, chassis - Page 191 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 8th September 2007, 07:53 PM   #1901
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Here's an interesting device i put together recently. A customer who bough Patek had too much gain with the amp and asked me for an attenuator.
I made a simple adaptor, using Cardas hardware and nude Vishay, it came out really nice (and compact).
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 8th September 2007, 08:09 PM   #1902
Originally posted by nycavsr2000
I always wondered what portion of your business was for kit builders/diyers. I'm assuming its pretty small ? Two different markets indeed.
Hi Anand,
The kits, or mostly chip amps, have been going steady for last 4 years or so. I'm still surprised that even when I'm not updating my website I get constant flow of orders. This is probably one of the best diy products ever invented
It's also good that I'm not only concentrating on kits but completed amps as well. When one portion of the business is slower, the other makes up for it
Below test report on Premium amp (kit) published recently in Hi-fi news.
www.audiosector.com
Old 8th September 2007, 08:41 PM   #1903
Frode is offline Frode  Norway
Originally posted by Peter Daniel
Changing the gain by adjusting R3 may affect sonic signature of the amp. Placing 22k input series resistor (in place of R1=220R ) shouldn't probably have that much effect.
I didn't try any of those methods though, as I'm not using any active preamp and more amp gain was always desired.
I don't use an active pre either, but I have very efficient speakers and I've had trouble with too high gain earlier. I guess the best thing is to try both methods. After all, some resistors won't ruin me.
Frode
Old 8th September 2007, 09:52 PM   #1904
arild is offline arild  Norway
Default CS8412
Peter
Thank you for sharing that information, Send me the price on the CS8412 chip.
Ari
Old 8th September 2007, 10:00 PM   #1905
CS8412, SMD, is $15 plus $5 shipping.
www.audiosector.com
Old 9th September 2007, 06:33 PM   #1906
karma is offline karma  Canada
karma's Avatar
hi peter i just started unpacking some of my audio from the move and i have lost the screws to my Integrated Chassis. i was wondering if i sent you a money order to buy the high end dac 1
chassis for $220 would you have any screws i could get off of you? im in a real pickle here i should have kept it together
if so ill e-mail you with your webpage e-mail for your mailing adress
thanks
dave
Old 10th September 2007, 03:08 PM   #1907
Yes, no problem. I can supply you with another set of screws.
www.audiosector.com
Old 10th September 2007, 08:55 PM   #1908
karma's Avatar
thanks
Old 14th September 2007, 11:26 AM   #1909
rnzr is offline rnzr  Estonia
Default my new gc
hi,
a little showoff of my new gainclone
it's a premium kit with elna silmics and silver solder/ silver wires etc. with 2 inputs and one "rec out" - straight signal output without pot, also it will give the mute function to my amp in this position (i use the "rec out" with my headphone amp, then i dont need to connect the cables from sources directly to my headamp each time)
greets, ronald
Old 14th September 2007, 02:37 PM   #1910
Poseidon's Voice
Wow! Very sweet! Peter Daniel would be proud! Professionally done! I like your website as well. Love the understated look of the whole unit.
Best,
Anand.
Copyright ©1999-2017 diyAudio
