| Audio Sector Kits & PC boards from AudioSector |
#1871 | |
Dear Peter. Are you aware of that your phono amp gives your DAC some serious competition? I ordered two Cinemag CMQEE-3440A transformers and hook them up before your phono amp. This combo really plays music! I haven't tried the S&B transformers you use. But they have to be really good if they shall defend their price tag. But the sound is of course first of all determinded by your phono amp. You have to produce this commercially! The music lovers deserve it! I have not played music on the cd player/dac combo for a week. Thanks again for your offer and giving me this opportunity to have this gem of a phono amp. Best wishes Jan Ove PS If you come of with other products that offer this musical quality, you have to tell me ;-) |
#1872 |
Hi Jan,
I'm glad you like that phono amp. For anybody intersted, the circuit was described here: http://www.diyaudio.com/forums/showt...20#post1123520 (RIAA section based on VSPS) It was actually the first phono stage that I've built recently and the one that I still have the biggest sentiment for. I later tried phono cube clone (the real one) and Pass Ono, but none of those played that good without the need for extensive mods and tuning. In fact, none of that is completed yet. Below picture of my original setup.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#1873 | |
I still use LM4780 in bridged configuration in one of my systems and it performs well. Probably the easiest way to get balanced signal from unbalanced source is to use matching transformers. Here's the affordable solution that performed really well (I tried it): http://www.edcorusa.com/products/tra...sm10k-10k.html
#1874 | |
![]() I described some of my mods here: http://www.diyaudio.com/forums/showt...594#post901594 I later did a bit more, which I did not described. I bought that unit more than a year ago and it's been in my system ever since. Initially, it didn't sound to me as good as the modified NOS DAC, although I could detect some hidden potential. After the mods, I would say it's some 10-20% better than NOS DAC, it has more refinement, when NOS can be still a bit rough on the edges or a bit colored. NOS DAC on the other hand offers probably more raw energy. For best results, Bidat needs to be modified, otherwise it sounds veiled and a bit boring.
#1875 | |
http://audiosector.com/lm4780%20amp.pdf http://audiosector.com/lm4780%20psu.pdf Cz and Rz are optional Zobel parts. I don't use them with the kits as they affect the sound in a way that should be avoided.
#1876 | |
Somehow, I don't feel tempted to add output devices to the chips; it's either chip by itself or completely discreet circuit.
#1877 |
Peter,
what happen to your DAC, last time I visited I could find any on sale? |
#1879 |
all links are upgrades and fixes, if i am interested in BUYING one should i talk to directly?
since you are here, questions incl.: 1. Price 2. options 3. technical specs. many more, that is why you should put info on yr site rather than repeating yourself. |
#1880 |
BTW, recently a customer who bought one of the DACs some years ago asked to have it modified into balanced version.
Here's how it came out ( I added another DAC board, the circuit reversing DATA phase is glued to receiver chip).
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| sucht |
| Page generated in 0.10791 seconds (66.57% PHP - 33.43% MySQL) with 11 queries |
