Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 27th August 2007, 07:10 AM   #1861
JHelms is offline JHelms  United States
Ok new pics All in the proper place *LOL* Not quite as perfect as the first time around but clean enough for me. Was a pain de-soldering the caps and re-installing them
Old 27th August 2007, 08:54 PM   #1862
rickmcinnis is offline rickmcinnis  United States
Default a DANIEL LME49810 based amplifier?
Just wondering if there is any chance you might be experimenting with this.
What do you think of it?
Any chance of making aPCB?
Thanks,
Rick McInnis
Rick McInnis
Old 27th August 2007, 09:31 PM   #1863
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
AudioSector-chip amp kits, dacs, chassis Send a message via AIM to Peter Daniel
I'm not really into those driver chips, but you can get nice boards from here:
http://www.chip-pcb.cn/7300/49810-A.htm
http://www.diyaudio.com/forums/showt...69#post1248269
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 27th August 2007, 10:35 PM   #1864
Default I had seen those ...
I have heard some interesting rumblings about these things and thought MAYBE you had some ideas for implementation.
What is responsible for your hesitation in using these? If there is anything more to it than time?
It seems like the next step from the LM3875.
Thanks,
Rick McInnis
Rick McInnis
Old 2nd September 2007, 02:39 AM   #1865
richyrich212t is offline richyrich212t  Canada
Peter,
what are "cz" and "Rz" used for on the lm4780 kit ??
Old 2nd September 2007, 02:53 AM   #1866
Greg Erskine is offline Greg Erskine  Australia
Greg Erskine's Avatar
z=zobel
Greg Erskine
Old 2nd September 2007, 10:18 AM   #1867
arild is offline arild  Norway
Default Bridge peter's LM3875
HI
this is my first post on the forum, i currently have the CT101 line stage from DACT http://www.dact.com/html/line_stages.html i would like to use peter's NOS DAC and four of his LM3875 ampifiers bridged into two 100W mono blocks, what do i need to do to bridge them since neither the DAC nor Pre have balanced outputs? could i us a transistor that changed the phase 180 degree's and if so does anyone have any suggestions for transitor type an a circuit for this? i found this on elliott's page http://sound.westhost.com/project14.htm i suppose this would work but looking for other designs as well. I would appreciate any comments to this setup since i am a newbie, i would like some recommendations. Even though my speakers are sensitive 95db i would like to pursue a higher power setup unless you guys strongly disagree!
Thank You
Arild:
Old 2nd September 2007, 10:34 AM   #1868
bridged suits high impedance loads.
It produces twice the power into double the load impedance.
However, current becomes the limiting factor.
50W into 4ohms is a very demanding spec for a chipamp, even though many builders go this route.
I would recommend you aim for 30W into 4ohms and and when bridged will give 60W into 8ohms. This will give about 108db maximum at 2.5m with your speakers. That is a very high level.
Alternatively, just go single and aim for 50W to 60W into 8ohms.
If your speakers are of a severe load type then consider parallel operation. This overcomes the current limit difficulty.
regards Andrew T.
Old 2nd September 2007, 02:33 PM   #1869
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
Peter:
I saw a recent post of your linking to where you describe some mods to the Meitner bidat. I currently own one and love it. Given this, do you have a recommendation for a NOS DAC kit, and how does it compare to the Meitner? Any kits that use the TDA1547 that have a similar flavor (or better!) than the bidat?
Thanks!
Old 4th September 2007, 12:15 AM   #1870
HI Andrew
Thank you for the information, That would simplify things a little as well since i am a newbie. I can always try to parallel and such later to see what works best for my speakers. I have to decide on what amp to start with, i was set on the LM3875 but should i go for the LM4780? heck maybe i will just order both and find out for myself, as long as i can use the same power supply looks like the LM4780 are quite flexible to supply voltage http://www.national.com/cat/?i=289. Do you have a preference between the two amp's
Ari
AudioSector-chip amp kits, dacs, chassisHide this!Advertise here!
