| Audio Sector Kits & PC boards from AudioSector |
#1851 |
Peter,
Do you have an assembly manual available for your lm4780 kit??? |
#1852 |
I never thought an assembly manual for such a simple circuit was needed.
You can find schematics for amp and power supply sections here: http://www.audiosector.com/lm4780.shtml If you click on Application Notes link, it will get you to pics and short info I posted on a Forum.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#1853 | |
Banned
Simple for you Peter, not simple for others, however he may just be wanting instructions so he can build it 100% perfect so he has no troubles. Just a thought. Jase |
#1854 |
I don't see how to make better instructions than what already has been posted: http://www.diyaudio.com/forums/showt...565#post636565
#1855 |
thats a great pic, but it is difficult to find without digging through 75 pages of info!!!
do you have a Power supply pic like that??? |
#1856 |
When I released both amp boards, I posted detailed instructions here on a forum, in this thread. To make it easier find it later, I made links from the pages describing each kit; just click on 'Application Notes" shortcut.
The PS for LM4780 kit is basically the same as for LM3875, and you can see it here (LM3875 PS): http://www.diyaudio.com/forums/showt...429#post584429 Please note that in LM4780 PS diodes are reversed though, and black stripes always indicate metal tabs.
#1857 |
Daniel,
thank-you for the pics!! |
#1858 |
Deleted
#1859 |
Banned
Very Nice, good work, looks like you took some time and did a very nice detailed job.
#1860 |
Yeah well.. new pics later. Seems like I have the caps on the wrong boards.. guess the higher end components have different values than the schematics
... DOH.
