Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 2nd June 2007, 01:41 PM   #1791
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
Default how many power output
for your product
- lm 3875 = ..... watt / channel
- lm 4780 = ..... watt / channel
that price for two channel ?
how about PSU ? are sale it too ?
thanks for your information
Old 9th June 2007, 03:28 AM   #1792
JHelms is offline JHelms  United States
Received my package, everything looks perfect! Man the board looks 10X better in person than in photos. A VERY professional product and I am very happy with everything! Will post pics soon!
Old 10th June 2007, 08:06 AM   #1793
AlanElsdon is offline AlanElsdon  England
Default NOS DAC Premium Kit
Peter,
I have built the Premium NOS DAC kit and it has been running for about 5 hours. Reading peoples comments about this DAC did not prepare me for how it sounds in my system. It is the first time in using a digital source that I start to hear what I get from vinyl - and that is saying something!
My digital front end is QNAP TS101 320GB NAS feeding into a Squeezebox (SB3); after the DAC is a Promitheus TVC followed at the moment by an LM3875 Basic kit Gainclone (I did initially use the LM3886 but quickly changed to the 3875) into Spendor BC1s.
I am really looking forward to getting my Linkwitz Orions running with a set of gainclone amps but for the moment I am happy to listen to the system as it is and to hear how the DAC settles in.
Many Thanks
Alan
Old 12th June 2007, 12:32 PM   #1794
orto is offline orto  United States
orto's Avatar
Would a 330v toroid be overkill for a single paralleled lm4780? I managed to find two of them with 25+25. I'm trying to decide if I should use one for both channels or one for each.
Old 12th June 2007, 04:51 PM   #1795
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
AudioSector-chip amp kits, dacs, chassis Send a message via AIM to Peter Daniel
330VA toroid will work fine per channel and won't be an overkill.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 12th June 2007, 04:53 PM   #1796
Here's an interesting device i put together recently. A customer who bough Patek had too much gain with the amp and asked me for an attenuator.
I made a simple adaptor, using Cardas hardware and nude Vishay, it came out really nice (and compact).
www.audiosector.com
Old 13th June 2007, 03:45 PM   #1797
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Andrew Rothwell does some good in line attenuators. They also can make them to suit the attenuation you require.
http://www.rothwellaudioproducts.co....tenuators.html
Old 24th June 2007, 06:47 AM   #1798
lordvader is offline lordvader  Australia
Default Aargh ! DAC not working !
I finally started testing the DAC, but it's not making any music !!!
I started the tedious task of measuring the voltages on each of the ICs, and here are my results :
The only thing that doesn't seem right, is that on the schematic, pin 5 and 6 on the receiver got to pin 10 and 9 (respectively) is the CS8412, but on the board I've got, they go to 9 and 10 ...
There are no shorts on the SMD components, and I get 4V before the output capacitors (am using 0.47uF), and get 0V DC after.
Code:
SN75179      TDA1543
1: 5V        8V
2: 4.5V      2V
3: 4.5V      2V
4: 0V        0V
5: 5V        8V
6: 0.5V      4V
7: 2.3V      2V
8: 2.3V      4V
CS8412
1-3 : 2V
4-7 : 7V
8 :   2V
9 :   5V
10 :  0.5V
11 : 2V
12 : 7V
13 : 0V
14 : 2V
15 : 7V
16 - 19 : 0V
20 : 2V
21 : 0V
22 : 5V
23 : 0V
24 - 25 : 7V
26 - 27 : 2V
28 : 7V
Old 24th June 2007, 07:18 AM   #1799
It seems that the regulator supplying VD on the CS8412 is a 7V regulator (not a 5V one)!!!
Have I fried the chip ? (please say no !)
Old 24th June 2007, 01:08 PM   #1800
OK, found the problem (silly me).
Earlier I put a capacitor in the wrong place. Removing it left some solder closing the hole, which couldn't be removed, so I "scraped" it away, and put the correct cap in.
Now I realised that all that "scraping" removed the copper that joined the ground from top of the board to bottom. A wire jumper now connects the grounds, and the DAC is finally making music !
Albeit everything is connected with aligator clips ...
Sorry for spamming the board !
AudioSector-chip amp kits, dacs, chassisHide this!Advertise here!
