| Audio Sector Kits & PC boards from AudioSector |
#1771 |
I received some enquiries with regards how to mount crystal oscillator in USB DAC: the pads went over footprint overlay and it's not clear what is pin #1. So I mark each board by engraving a small dot next to pin 1 (on the oscillator).
Below is the pic showing proper footprint.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#1772 |
The oscillator can be sourced from Mouser: http://www.mouser.com/search/refine....9-C3391-12.000
#1773 | |
Peter, Thank you for your response. Just one thing: how to calculate the regulated voltage? I had thought that the rectified and smoothed voltage would be the RMS the peak to peak, (x0.707 IIRC), doubled up for + and - supplies (previous post). That's where I got the rough estimate 1.4 x VAC, and the figure of 25V secondaries for 35V rails. You say 2x24VAC => ~37V DC, but I make it 34VDC. I'm sure you're right, but how do you do the calculation? What is a usual margin for 'usually higher mains level'. Mine (nominally 230V) reads *exactly* 230V. Now that my LM3875 kit is in the post (thank you), I'm on the point of ordering the transformers. I was going to go for 2X25V, but now I'm not so sure... Best wishes to all, Steve
A gentleman is a man who can play the accordion but doesn't. ..... Oscar Wilde |
#1774 |
Transformers I'm using are rated for 115V and my mains are usually 120-123 V.
Also, you need to take into account regulation margin which may be another 6%. That's why the actual voltage is usually higher than expected.
#1775 |
Peter, would there be any benefits to using a tentlabs oscillator? the package is different but I guess i could just solder the leads to the pads on your pcb....
Greg |
#1776 |
Peter I'm wondering about MSR860s. e.g., d1-d4: it looks like on the s chematic and the pics you posted are at odds. looks like d1's anode, pin 3, should be connected to the transformer, but that doesn't look to be the case in the photo you posted earlier. Did anything change from earlier photos? thanks
Greg |
#1777 | ||
#1778 |
Hii Peter
Do you research about dac too ? are you sell it [dac] ? just pcb, pcb+kits or full pcb ? thank you peter |
#1779 |
#1780 |
hii Peter
sorry not to read all your post in this thread im afraid i will sleep in front of my computer LCD 178 page ... wow ![]() maybe you must talk to moderator to split this posting into 3 thread Oh yes you are very famous in Indonesia i know for sure you never come here yet i will tell this dac to my friend, byee |
| Page generated in 0.14950 seconds (77.32% PHP - 22.68% MySQL) with 11 queries |
