AudioSector-chip amp kits, dacs, chassis - Page 171 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 11th April 2007, 01:37 PM   #1701
DeanP is offline DeanP  Canada
Vorpal,
I built a six channel last year using three chips and three ps with two transformers.(23 +23,400va from Antek). I am going to rebuild again this year adding two parallel channels plus two active x-overs.
These chipamps are excellent with great clarity and power! I upgraded from a Rotel amp and noticed a big difference!
I have aproblem with a ground loop but it is because I used two ps for one trannie, When I rebuild,I will use only one ps per trannie and it should take care of the ground loop issue. Check out the chipamp threads, there are plenty of threads on this issue with a recent one definitely showing that one ps per trannie will stop ground loops.
So all in all, I highly recommend Peter's kits! Easy to follow instructions. I bought my trannies from Antek from e-bay though I noticed Peter sells Plitrons.
Yes! Its cold in Cold Lake...
Old 11th April 2007, 07:31 PM   #1702
vorpal is offline vorpal  Canada
Great! Thanks for the quick reply man!
What do you use to turn the amp on? Is it auto-sensing?
Would you recommend buying 5 kits and bridging them? Would that be an option?
Just trying to figure out what the best would be. Would I be anywhere close to 150w/channel?
Thank you.
Old 11th April 2007, 08:08 PM   #1703
To turn the amp on,I have a 120vac relay which is plugged into my reciever, so when the reciever turns on it trips the relay, turning the amp on.
Depending on what "ohm" speakers you have will depend on what configuation you can do. Use on chip for two channels for 8 ohm speakers and use one chip in parallel for 4 ohm speakers.
So you would need anywhere from 1 1/2 kits to 3 full kits.
As for watts/channel, my amp delivers an unknown amount of watts(maybe 60-70) but compared to my old Rotel @ 150w/channel, this chipamp is no slouch!It goes louder with less distortion!
If you go to HTGuide.com and search out gainclone, you will find my 6 ch amp there. I go by the same name there.
Old 12th April 2007, 06:00 AM   #1704
rjkdivin's Avatar
I finally got my two ALL-In-One DACs put in cases....one black, one Alodine Clear. I retrofitted Tent Labs XO-DACs at 2.8224MHz, added power switches and power indicator LEDs. I've left room for Peter's USB adapter board and a selector switch.
I powered the XO-DAC from one leg of the on-board PSU and the LED from the other....seems not to cause a problem....what do you think Peter? Should I add another PSU? Also, when the USB board is added, can it run off the same PSU?
Photo1 Photo2 Photo3 Photo4
Old 12th April 2007, 06:24 AM   #1705
How were you able to connect an "external" clock to the board ?
Old 12th April 2007, 08:08 AM   #1706
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Looks good. I would run the XO-DAC from the same supply as CS8412, same for the LED, but connected directly to the first cap (C3). That will provide some filtering and separation between DAC and the additonal circuit. I understand XO-DAC comes with on board regulators, so it should work fine this way.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 12th April 2007, 11:47 AM   #1707
hayena is offline hayena  Czech Republic
recently, i constructed another chipamp using Peter's boards and with similar connection as the Patek (with cheaper parts) ...
Unfortunately, there is no sond comming out of speakres except significant buzz in th eright speaker - the left channel is totally silent. I also noticed that the chip on buzzing channel is getting very very hot...
any idea what the trouble might be?
Thanks.
hayena
Old 12th April 2007, 11:50 AM   #1708
...and the view from above
hayena
Old 12th April 2007, 02:04 PM   #1709
rjkdivin's Avatar
The trace from pin 12 of the CS8412 is cut on the back of the PCB. The XO-DAC input wire is taken from the CS-8412, and its output is taken to pin 1 of the TDA1543. This replaces the clock output of the CS0412 with the clock from the XO-DAC. The grounds for the input and output of the XO-DAC are taken together to the ground trace in the signal circuit of the AllInOne....I used the ground pad for the analog out RCA jacks. Guido Tent's documentation for the XO-DAC is quite good.
Robert
Old 16th April 2007, 09:19 PM   #1710
Default LM4780 Mute resistor
This being my first experience with a SMD ...
I dropped one on my black floor and it is limpossible to find (so far).
Is it important for this SMD component to be used or could one use a CADDOCK (I am sure this is overkill in the extreme, but, at least, the pins are easier to fit the pad)?
Thanks,
Rick McInnis
Copyright ©1999-2017 diyAudio
