#161 | |
That hi res pic with macro looks SUPER!!!!
Baby Danika, Born January 20th 1:54am.. http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect.. |
#162 | |
diyAudio Moderator Emeritus
http://www.dpreview.com/reviews/canonpro90/ -- Brian |
#163 |
Here's the DAC built with a green board. It is probably one of the first built by someone else than me
The only difference to premium version is use of Panasonic FC caps intead of BG NX (4 x 1000u in PS)
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#164 |
Peter- You Got Mail..
#165 |
Before the DAC section on a website is up and running, here's the info regarding the circuit, options and prices.
Two boards are available: the all-in-one solution with integrated PS and all connectors PCB mounted; you will only need a piece of wood to put it on and it can work this way. It actually sounds better without a chassis and this is how I use it: http://www.diyaudio.com/forums/showt...611#post599611 This board is $35. The second board, does not accomodate transformer, and it has to be mounted separately. This is designed with exact the same parts in mind as the first one, additionally it can also accomodate 2 regulator circuits, acting as battery chargers, (if someone wants to use battery power). This board allows direct mount of both RCA and BNC input and RCA output (dual Vampire type) http://www.diyaudio.com/forums/showt...709#post604709 Let's call it a green board and it is available at $30. Attached is circuit schematic, which with addition to one OsCon before U1 regulator in a first board, is the same for both.
#166 |
can you get the all in one with a rca instead of a bnc input?
http://www.caraudioconnoisseur.com/ |
#167 | |
I belive so. : O )
#168 |
How difficult might it be to adapt the PCB to handle optical input?
#169 |
Schematic shows the type and parts values. This is quite critical for the DAC sound signature, and this is how I liked it. The actual combination makes the TDA1543 to sound very natural, open, harshless and neutral, with well defind soudstage, articulate midrange, and very tight bass; the big strengths are musicality and involvement. At present, I don't see any reasonable way to improve it. I'm using BG N caps for coupling and believe me, they are better here than MIT RTX, Siemens MKV, Russian paper in oil or Jensens (copper foil). I'm quite sure that the new V-caps are better, but this is not a reasonable way to improve that DAC
![]() The premium DAC kit will contain the boards and the following parts: MSR 860 8pcs Line Filter 2pcs Dale 20R resistors 4pcs 1000/25 BG NX 4pcs Ferrite Bead 3pcs AN8005 3pcs AN8008 1pc 10/50 BG N 2pcs 47/50 BG N 1pc 15/20 OsCon 1 or 2pcs 4.7/50 BG N 2pcs 3n3 PPS film cap 1pc 330R Caddock 1pc 0.47/50 BG NX 1pc 75R Caddock 1pc 10n Vishay 2pcs SN75179 1pc CS8412 SMD 1pc TDA1543 1pc 2k7 Riken 2pcs 1k5 Riken 1pc BNC jack 1pc The cost of All-in-One DAC kit is $210 The cost of Green DAC kit is $200 None of the kits contain RCA jacks, transformer, fuses or power modules. Those can be obtained separately and the prices are as follows: PCB mounted Hammond 229D16 transformer (including power entry module and fuse): $30 Cardas double RCA Female, PCB mount: $20
#170 | |
| Thread Tools | Search this Thread |
| Page generated in 0.12831 seconds (67.63% PHP - 32.37% MySQL) with 11 queries |
