AudioSector-chip amp kits, dacs, chassis - Page 163 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 26th March 2007, 02:18 AM   #1621
Hi Peter,
I've finaly put your LM3875 Premium Kit in is final enclosure. But I'm having some problems: I can hear a radio station in my speakers. Any solution for this problem?
Thanks,
Paulo
Old 26th March 2007, 03:17 AM   #1622
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
That may be caused by some grounding issues. I posted my preferred grounding method here: http://www.diyaudio.com/forums/showt...773#post787773
Also, you may try to install 300pF capacitor between positive and negative chip input, more info can be found here: LM3886 very prone to mains noise
You may also see if installing Zobel components (Rz=2.7R, Cz=0.1uF) changes anything.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 26th March 2007, 11:47 AM   #1623
Thanks Peter, I'll try that 300pF capacitor. Just one question, by positive and negative chip input you mean in the rca's ou directly in the board? And the Zobel components won't have an impact in the sound?
Paulo
Old 26th March 2007, 03:29 PM   #1624
The 300pF cap mounts directly to chip pins 7 and 8, there is no separate footprint for it on the board.
More than likely, Zobel won't help here, but it won't hurt to try. And yes, it will affect the sound: you may like it or not
www.audiosector.com
Old 26th March 2007, 03:39 PM   #1625
OK, just one more question: what kind of cap (ceramic, electro, any kind)? Sorry for the newbie questions...
And with monoblocs how do I apply your grounding, because I can't connect the OG's.
Thanks for all the help
Paulo
Old 26th March 2007, 04:22 PM   #1626
I'm using polystyrene caps here.
That grounding method was specifically for stereo amp. Monoblocks are much more forgiving to grounding errors and if you wire them in conventional method (4 wires from rect board to amp board) it should work fine too. You may experience problem though, if Earth ground is connected to chassis, in that case connect output ground to chassis instead (from negative speaker post) and Earth ground not connected (to chassis).
www.audiosector.com
Old 27th March 2007, 06:45 PM   #1627
Poseidon's Voice
Default Audiosector NOS dac completed!
Hi guys,
Finished the dac . Currently breaking in. I added a HagUSB board as well (modified with Lundahl pulse transformer, BG caps, Caddock resistors).
Enclosure is Michael Woods' 0908 enclosure from DIY enclosures
Check it out. Thanks for all your help
Comments, questions, advice...welcome! Other pics here on audiocircle:
Poseidons Voice NOS USB dac
Anand
Old 28th March 2007, 07:53 PM   #1628
Facing the competition from various group buy offers, I decided to introduce new version of LM4780 board. Since my cost is also lower now, I'm passing the savings to potential buyers. The board as you see in a picture is $20.
www.audiosector.com
Old 28th March 2007, 07:58 PM   #1629
In other words you are getting two separate LM4780 PCBs at $10ea, as pictured below. Untill I do changes to my website, those prices will also include worldwide shipping. If you order larger quantities, further discount will apply. Just contact me directly through PM.
www.audiosector.com
Old 28th March 2007, 07:59 PM   #1630
That offer also applies to LM3875 board, which is available in the same format.
www.audiosector.com
Copyright ©1999-2017 diyAudio
