| Audio Sector Kits & PC boards from AudioSector |
#1611 | ||
Banned
I think i spent more on the buffer than i did the usb part. Quote:
#1612 |
$30? - I am definately down for one of these babies
- J |
#1613 |
get in line, no pushing
http://www.karmaelectronics.info |
#1614 | |
I would like to add the USB board to my existing SPDIF Premium and Green Board DACs in the switched configuration you mentioned. I'm finally getting around to building the cases for them, so your timing is perfect......I just need to modify the case size a little bit. When do you think you will have them ready for sale? Robert |
#1615 |
What value slow blow fuse are people using with their DACs in the US/Canada region (110V)?
Thanks, Anand. |
#1616 |
1 or 2 A is what I'm using. A tried few different types and digikey part# 507-1032 seemed to create least "damage"
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#1617 | |
#1618 | |
and the recommended transformer) best wishes Jan Ove |
#1619 |
With 230V, I would go with 1A for the DAC and at least 3A for GC.
With 115V and 300VA toroids I'm using 6A fuses.
#1620 |
Thanks a lot, Peter. Seems I have to replace the fuse right now!
best Jan Ove |
