Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 24th March 2005, 06:36 PM   #151
karma is offline karma  Canada
karma's Avatar
im most interrested in buying one when thay become Available.
what round about price would you be looking at for this dac?
if you dont mind me asking.
i need to hide money from the old lady to buy one
Old 24th March 2005, 07:19 PM   #152
Ditto
Old 24th March 2005, 07:33 PM   #153
revell is offline revell  Belgium
The inclosure is pretty simple, yet functional. I'm using 3 x 2 aluminum tubing, with end caps attached, sort of Amp-1 styling
How do you actually attach those endcaps? I can't see any screws, and I don't think they're glued
Old 24th March 2005, 07:54 PM   #154
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
The ones in a pictures were actually glued. This was prototype and I didn't have the time to order machined pieces, so I cut them myself from 1/4" plate. The front plate can be mounted permanently and the board is only attached to rear plate and slides out. The rear panel is attached to board, the board attached to the bottom with 6 screws.
However, in a final version both plates will have milled out notch that goes inside tubing and is press fitted. One screw on bottom will provide additional security.
This is the same way that AMP1 and PS are made.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 24th March 2005, 07:56 PM   #155
Here's the picture showing it better:
www.audiosector.com
Old 24th March 2005, 07:57 PM   #156
The complete DAC will be selling for at least $900 under Audio Zone name.
I still didn't figure kit prices, but they will be rather affordable
www.audiosector.com
Old 25th March 2005, 05:51 PM   #157
karma's Avatar
ill hold out for the kit. kinda take the fun out of it buying it already together.
thanks..
Old 28th March 2005, 11:20 PM   #158
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Received the boards today. The gold on the boards looks great with the clear soldermask, much better than the pictures!
I hope to put the dac together soon
Thanks,
Brian
Old 28th March 2005, 11:33 PM   #159
BrianGT's Avatar
Here is a picture with the Sounds Connections (Vampire Wire) rca connector, which has the same footprint as the BNC.
Brian
Old 28th March 2005, 11:39 PM   #160
BrianGT's Avatar
Another picture.
Brian
Page generated in 0.09488 seconds (76.79% PHP - 23.21% MySQL) with 11 queries
