Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 2nd February 2007, 06:46 AM   #1541
dake13 is offline dake13  United States
dake13's Avatar
Unhappy Help w/3875 power supply
This is embarrassing... Peter, I ordered one of your kits quite a while ago to build for a friend (last summer?). Turned out the kit ended up being for me, but one thing led to another and I've never finished it...
This is the premium LM3875 kit, which I was trying to put together as a dual mono amp, passive volume and chipamp in one chassis, and two separate chassis for each channel's power supply. Also, the main thing that was giving me trouble was, I'm trying to wire it up with a DPDT switch to switch from 120V to 230V mains. The trannie I'm using is:
http://www.plitron.com/shopping/specs/0770XX201.pdf
300VA with 24V secondaries.
So I thought I knew how to wire it together, and I plugged everything in, and 'POOF!' The fuse blew and there was a loud sound from the speaker (I only wired it up for one channel). I hope I didn't do any damage to the amp.
I've come to the conclusion, that even though I've done a little diy'ing, I'm out of my depth here... the instructions don't cover what I'm trying to build. (If worse comes to worst, I could ditch the DPDT switch).
Could one of you kind souls take a look at this little diagram and tell me what hooks up to what? I need some remedial help here.
It may just be the DPDT switch. Thanks.
Old 2nd February 2007, 01:34 PM   #1542
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
AudioSector-chip amp kits, dacs, chassis Send a message via AIM to Peter Daniel
Unless you plan to use transformer with 230V I would not recommend any DPDT switch on primaries. Here's the link to Plitron connection diagram : http://www.plitron.com/standard_schematics.asp
All the other info you will find here: http://www.diyaudio.com/forums/showt...threadid=94300
Before connecting amp to PS check for correct voltages first, before connecting speakers to the amp, check for DC offset (it should be below 100mV on speaker terminals)
To order kits contact me through forum mail.
Old 2nd February 2007, 02:10 PM   #1543
RKH is offline RKH  United States
Default dual RCAs in DAC
Hi Peter,
Do you know if these Vampire pcb mount dual RCAs fit your DAC boards (w/o mods that is)?
http://vampirewire.com/mcart/index.c...3&page=2&cat=5
(Towards the bottom of the page)
Thanks,
Ryan
Old 2nd February 2007, 02:22 PM   #1544
The first dual RCAs on a page (Part #PC2V ) will fit the Green board. The gold board accepts only Cardas dual connectors. You can also make them yourself:
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Old 2nd February 2007, 02:59 PM   #1545
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Peter, the king of fabrication
Hey, is that digi volume control remote controlled as well?
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 2nd February 2007, 03:07 PM   #1546
Yes, it works with RC5 coded remotes (Philips, Daewoo, LG).
Old 2nd February 2007, 03:39 PM   #1547
paulomartires is offline paulomartires  Portugal
Peter,
just to say that i'm wainting for your phonostage
Next month i'll probably buy your DAC.
Old 2nd February 2007, 03:47 PM   #1548
I'm actually working hard with phonostages. I started with a phono section based on VSPS (RIAA circuit only with all the rest changed and OPA627 used) and it worked surprisingly good. The step up was done by S&B TX103 (for Shelter 901)
If there is an interest, I can post detailed schematic.
Old 2nd February 2007, 03:50 PM   #1549
The second circuit I tried was ONO. I used what I thought the best parts and because I couldn't decide which version of PS to choose I run it from batteries. But I was not blow away after switching from OPA627 circuit, in some ways I think the other one was smoother. I may have overdone with all those Premium part in ONO ;-)
Old 2nd February 2007, 03:52 PM   #1550
I still need to build EAT834 and Jadis JP-80.
After I try them all, I should know which direction to go.
The phono preamp is positioned right beside the arm to minimize all the connections.
AudioSector-chip amp kits, dacs, chassisHide this!Advertise here!
