| Audio Sector Kits & PC boards from AudioSector |
#1531 |
A question on the DAC Peter. Is it normal to have a few volts of DC on the RCA output? This was only measured without any connections attached.
The reason I ask is, mine has always been set up as a single source and but now has a Elma for source switching. I'm getting popping during source changes only with the DAC...... all other sources clean. There's no problems with the sound as it's fantastic.
No longer DIY active |
#1532 |
The original design did not have resistors to ground after output coupling caps. So if you measure offset without load connected, you will see some offset. As soon as the DAC connects to a next stage, the offset disappears. This may create some popping when switching sources (depending how the preamp source selection is configured).
I still don't supply those resistors with a kit, as the DAC sounds better without them, however, with a new boards, I made space for them, and if needed, they can be installed (R11/R12 in a picture, 50k or so value)
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#1533 |
Many thanks for the info Peter.
#1534 |
This question seems ridiculous even to me, so I'm sorry in advance. I'm interested in a DIY DAC kit. Peter, it seems you have one available. Where are the details? I don't see any information on www.audiosector.com . Again, sorry if this is ridiculous.
#1535 |
The DAC is actually mentioned on my site, in May 2005 Latest News. I don't advertise it though, as such kit would be in direct competition with my commercial product, that has been recently reviewed here: http://www.6moons.com/audioreviews/a...e5/system.html
So, all marketing of the DAC kit is based on this thread and a word of mouth of happy customers.
#1536 |
Peter:
Is it still possible to purchase a "regular" kit with both RCA and optical inputs? As I understand it this would include everything with the exception of the transformer? This project is exactly what I'm looking for thanks very much for making it available to the DIY community. I read the review of your commercial products, very cool that you've been able to make the leap into producing your own commercial electronics. I'm sure thats very satisfying, good luck with it. |
#1537 |
Yes, the regular kit is also available. I can supply optical input as well, with a schematic how to connect it. All you would need is transformer (and toggle switch for input choosing)
#1538 |
Whats the damage ($) with shipping to USA zip code 29201?
#1539 |
The regular kit is $100, Toslink $10, shipping $11
#1540 |
Cool, great pricing. This includes the DIP version of the DAC? No SMD soldering right? How do you accept payment?
Side questions: * Has anyone modified this to use an external clock? As I understand it there is a way to "slave" a clocked device over S/PDIF by providing your own clock within the DAC? * Did the USB interface for this ever become available? If so, how much extra? Can it be switched along w/ the RCA and TOSLINK? |
