Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 15th December 2006, 11:15 PM   #1501
alienman is offline alienman  United States
Hi, I have a question about using a center-tapped trafo with the lm3875 kit, as none of my local suppliers has anything with dual secondaries. I'm wondering which method is correct, as posted here: http://www.diyaudio.com/forums/showt...382#post548382. I'd prefer to use Sherman's method, as I really have no use for 12 extra diodes
Old 20th December 2006, 10:22 PM   #1502
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
AudioSector-chip amp kits, dacs, chassis
I need to ask once more, will the 24v x 2 400VA (BG caps recommended in use) have any problems with impedence of a Squeeze Box?
Old 20th December 2006, 11:09 PM   #1503
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
AudioSector-chip amp kits, dacs, chassis Send a message via AIM to Peter Daniel
Sherman' method will work fine, although it's not exactly the same as dual secondaries.
I don't see a connection between impedance of a squeezbox and voltage supply of the amp? 2 x 24V is a good choice for the supply and should work well with most speakers.
To order kits contact me through forum mail.
Old 21st December 2006, 01:09 AM   #1504
Sorry, I guess the discussion on it had something to do with another type of Chipamp or something.
Old 5th January 2007, 08:33 AM   #1505
johnm is offline johnm  United Kingdom
johnm's Avatar
Hi Peter!
I built your LM3875 some time ago and it still gives me a great deal of listening pleasure a year down the line. I'm using 2 x 1000uF Black Gate standards at the bridge (PSU unit is in a seperate box), and 2 x 100uF Elna Silmics on each amp board (I will upgrade to Black Gate Ns at some point)... in other words it's a cut price Patek
Just wondering what your current reference is at present? Is it still 1000uF at bridge and 100uF on amp boards?
Many thanks.
- John
Old 5th January 2007, 06:15 PM   #1506
Rob Thomas is offline Rob Thomas  United States
Rob Thomas's Avatar
Let me just jump in here and reiterate how great MY premium Audiosector LM3875 amp(s) sound as well.
I've lived with this thing for some time now, and swap it in and out against very good 2A3, EL34, Class D and conventional amps and am always stunned at the quality of the little amp that could when I plug it back in.
Masterful.
-Rob
Old 5th January 2007, 06:41 PM   #1507
Yes indeed, it is still my reference; the circuit is hard to improve upon. The actual amp I'm using presently was described here: http://www.diyaudio.com/forums/showt...st+advanced%22
And I'm slowly getting myself into vinyl
Old 5th January 2007, 06:51 PM   #1508
Rob Thomas's Avatar
Is that a Shelter 901 or 501 I see?
I use the 901.
-Rob
Old 5th January 2007, 06:57 PM   #1509
mantisory is offline mantisory
Rob,
by the way...where did you get the lamp you're using above your table?
Byron
and peter - "Slowly" getting into vinyl and you're already using an SME V on an Oracle delphi...man, i wish i was that slow
Old 5th January 2007, 07:06 PM   #1510
Rob Thomas's Avatar
The Littlite gooseneck lamp was from http://www.Markertek.com
You can find them at MusiciansFriend.com and eBay as well. Get the brighter, halogen version.
http://www.littlite.com/main.php
-Rob
AudioSector-chip amp kits, dacs, chassisHide this!Advertise here!
