#131 |
And that's the back
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#132 |
Gee!
That looks beautifull! Excellent. Can't bring myself to buy another DAC since i have one (Scott Nixon Tube DAC). However if i didn't.... I really, really appreciate that you keep offering this high quality DIY-stuff! Gerben P.S. the Premium 3875 SE kit with the BG N 100/50 keeps getting better! Thanks for the suggestion. |
#133 |
Hi Terry,
I will definitely contact you with regards to help you offered on certifications research, as sooner or later I will have to go through that anyway. The topic has been interesting enough and I will ask moderators to split this part and create separate thread dealing with creepage and safety standards. I appreaciate everybody's comments. moderator note: new thread split off is here:Products certifications, safety requirements (and creepage distance)
#134 |
Now back to a main topic, which is the DAC. I've been receiving e-mails with regards to when it becomes available. I will work with Vikash on creating separate page for a DAC on my site. Meanwhile, the board is available and it is $35. The set of chips (CS8412 and TDA1543) is addtional $20. Set of 4 regulator chips (AN800X) and SN75179 input buffer will be $6.
All the other parts will be available as well. I still did not figure the total cost, but would like to offer two versions: regular with budget oriented components and price no object, Premium version. For those who don't need AC section on the board, I will be supplying another DAC board, which contains LM317/LM337 regulators intended to work as battery chargers. This board is made to accept also SMD version of receiver and can be used with outboard transformer as well. The board layout was created by Damian Antoniak, who is also a member of this forum (Veteran), with some assistance on my side. This board will be selling for $30.
#135 |
Peter, That board is Great looking.. Good job!!
Baby Danika, Born January 20th 1:54am.. http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect.. |
#136 |
To give you some idea what Non Oversampling TDA1543 DAC is capable of, I will quote here an article from January issue of Stereophile, by Art Dudley:
"An unfair comparison Perverse though it may sound given all the stunning software at hand, I couldn't resist comparing the dCS Delis DAC with the most different product I could find: a 47 Laboratory Shigaraki DAC. The Delius contains several hundred parts and provides every audiophile convenience imaginable, and then some; the 0x-oversampling Shigaraki contains literally 20 parts and doesn't even incorporate a digital or analog filter. Hey, sounds fair to me. The difference, as you may have guessed, was pretty obvious. The dCS Delius was so timbrally neutral and (aparently) accurate that it made the Shigaraki sound colored and lacking in frequency extention. The dCS made Paul McCartney's voice on "She's leaving Home," sound more real, more like Paul McCartney. Listening to the same recording through the Shigaraki was like hearing it through an old-fashined radio: The frequency response was slightly lumpy throughout the upper mids and highs, and it sorely lacked ambience, air, and reverb decay. The dCS sounded like high fidelity; the 47 Labs sounded a bit quaint. But the Shigaraki was at least as compelling, as the Delius-and I thought the music had more drama and texture straight through the Shigaraki than when upsampled through the Delius's 1394 connection. That distinction was equally pronounced on classical music. The burrial mass from Heinrich Schutz's 'Musikalische Exeqien', had more hall sound through the dCS converter, and was arguably smoother. But in upsampling mode, it was almost too smooth. By comparison, the relatively cheap Shigaraki DAC had more texture-including, I admit, more grit in the spaces between the notes-but was also more involving. .......Here's comment probably not germane to the spirit of this comparison that I'll make anyway: The $1400 Shigaraki wasn't the least bit embarassed by the $9995 Delius, although the latter's sophistication was obvious. After the first weeks of the review period, during which I did the bulk of my components swapping and note taking, many was the time I found myself leaving the Verdi La Scala (dCS transport [PD]) and Shigaraki combo in place- and enjoyed the hell out of it. I don't think the pairing is silly at all." The DAC I'm presenting here is as good as Shigaraki, but IMHO opinion, does not exhibit above mentioned coloration and provides more ambience, air, and reverb decay. It exceeds ML35 DAC in every aspect (I have one sitting useless on a shelf for the last 6 months) and the main strength of the smaller DAC is much bigger musicality, sense of realism and involvement. It is not ashamed by much higher priced equipment and presently I'm using it with ML31.5 transport and heavily modified ML380S preamp. This comination is quite outstanding indeed. ![]() Any comments on my new audio rack? I just finished it yesterday and couldn't resist temptation not to show it in here
#137 |
peter do you think your dac would be a good start for a newbie?
http://www.caraudioconnoisseur.com/ |
#138 |
While the first board I posted here (with clear mask) I would rather recommend for more experienced hobbyist (as it deals with mains voltage and requires 3-D assembly), the green one, that was presented here today, should not be a problem even for a novice.
#139 |
Congrats on your nice efforts Peter!
I have one question. In the 6moon review it stated that your DAC reversed abolute polarity. Is this still the case? It would not really be a problem as my only analog source will be the tuner (which may be inversed phase, I don't care). I just have to make a switch for my three digital sources (allthough BNC connectors are well suited for de/reconnecting...) |
#140 |
Nice rack Peter!
Looks like the DAC will have to go on hold for the moment, I have just put myself down for the miniA GB, and pocket money is still scarce. Still, I'm sure there will be new improved version 2 boards in a month or so, I know how much you like playing with designs...
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
| Thread Tools | Search this Thread |
| Page generated in 0.12343 seconds (55.78% PHP - 44.22% MySQL) with 11 queries |
